7 psi spring and only boosting 4 psi why?
Old Aug 25, 2003 | 06:57 AM
Nextelbuddy's Avatar
Default 7 psi spring and only boosting 4 psi why?
everything is connected properly and the car pulls real nice but its only boosting 4 psi according to the boost gauge. would my 2.25 inch exhaust piping and CAT cause this? some one told me that if i got rid of the cat and went to 3 in that iwould boost the full 7 psi is that tru?
Old Aug 25, 2003 | 07:14 AM
B18c1turboedEK's Avatar
Default Re: 7 psi spring and only boosting 4 psi why? (nextelbuddy)
You know why i think its becasue theres a 4 psi spring in it... thats just my tought!!!!
Old Aug 25, 2003 | 07:41 AM
Default Re: 7 psi spring and only boosting 4 psi why? (Koticcivic4u)
you think?? why would there be a 4 psi spring in there? i guess i need to get a boost controller then
Old Aug 25, 2003 | 07:54 AM
lazerus's Avatar
1.) You have a boost leak
2.) Your boost guage has a leak
3.) Your boost guage is innacurate
4.) To infinity and beyond!
There are a few ideas for you to check out. ;-)
Edit: Also make sure your vacuum source for the wastegate is behind the throttle plate.
Modified by lazerus at 2:31 PM 8/25/2003
Old Aug 25, 2003 | 08:37 AM
94TurboGSR's Avatar
Where is the gauge reading pressure from? Where is the wastegate line connected?
If you're sure everything is right and you're still getting 4psi, run open downpipe and see if you can build 7psi. If your gauge and wastegate are connected to the same vacuum source, and you still get 4psi... see if you can trade wastegates with someone for a test run.
Good Luck.
Old Aug 25, 2003 | 09:28 AM
Default Re: 7 psi spring and only boosting 4 psi why? (94TurboGSR)
i have a vacuum hose running straight from a nipple on my turbo to the nipple onthe wastegate, and i have a double TEE fitting between my intake manifold and fuel pressure regulator for my BOV and BOOST gauge. i think thats hiow its supposed to be
Old Aug 25, 2003 | 09:52 AM
nigel's Avatar
what kind of exhaust system do you have? because open down pipe I an boost to 6. and when I have my exhaust I only go to 4
Old Aug 25, 2003 | 09:54 AM
turbo*s2k's Avatar
I had that same problem with my drag 3 kit, but I ended up spinning a rod bearing before I corrected the problem... Don't know how, just did! Are you using the delta wastegate? I would switch to tial!
Knightsport's Avatar
El Chico
25 Year Member
Community Builder
Community Influencer
Try hooking an air compressor up to your boost guage and make sure it is accurate first.
Then, check all of your vaccum lines and hoses for cracks.
It doesn't sound like a bad leak or you woiuldn't be building ANY boost.
What does your butt-dyno tell you? Or did you ever drive it at 7psi before?
Old Aug 25, 2003 | 10:59 AM
94TurboGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">i have a vacuum hose running straight from a nipple on my turbo to the nipple onthe wastegate, and i have a double TEE fitting between my intake manifold and fuel pressure regulator for my BOV and BOOST gauge. i think thats hiow its supposed to be</TD></TR></TABLE>
Well, that's one reason you're reading less than 7lbs. You have pressure drop between the turbo and the intake manifold (intercooler, etc). If you tee the wastegate from somewhere else (FPR, manifold, brake booster, wherever) then you'll see higher boost. You may have a small leak somewhere else, 3psi of pressure drop seems like a lot.
Make sure you plug the hole on the turbo if you decide to take my advice, otherwise boost will leak there too.
Old Aug 25, 2003 | 11:04 AM
InTeGrA B18b1's Avatar
Fmic Boost drop mines drop 2 psi
Old Aug 25, 2003 | 11:56 AM
Vtec92Civic's Avatar
Default Re: 7 psi spring and only boosting 4 psi why? (InTeGrA B18b1)
I am having a similar problem accept I am not seeing any boost. My waistegate opens, I can hear the turbo spooling, but it doesn't really feel like much of a power gain, and my autometer boost gauge isn't reading anything maybe an occasional 1psi
Old Aug 25, 2003 | 11:59 AM
twkdCD595's Avatar
Default Re: 7 psi spring and only boosting 4 psi why? (Vtec92Civic)
what kind of wastegate?
deltagate?
Old Aug 25, 2003 | 12:57 PM
red cx's Avatar
Default Re: 7 psi spring and only boosting 4 psi why? (twkdCD595)
I have a 9 psi spring in my tial waste gate and after i installed my fmic i dropped 2 psi. also check your exhaust unbolt your down pipe and go for a quick joy ride. See what happens then go from there.
Old Aug 25, 2003 | 01:06 PM
Happyman's Avatar
Default Re: 7 psi spring and only boosting 4 psi why? (b16aturbopwrd)
I have an intercooler and the stock greddy psi is 5.5 psi. How come my VAFC reads .38-.41 mmhg which equates to about 5.5-5.8 psi? Should I have had a boost drop too?
Old Aug 25, 2003 | 01:07 PM
streetrays's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec92Civic &raquo;</TD></TR><TR><TD CLASS="quote">I am having a similar problem accept I am not seeing any boost. My waistegate opens, I can hear the turbo spooling, but it doesn't really feel like much of a power gain, and my autometer boost gauge isn't reading anything maybe an occasional 1psi</TD></TR></TABLE>
Now that's boost leak or some real problem. And as for the 4 psi on supposedly 7 psi spring, I think it's just pressure drop, i'm experiencing the same thing before, but i turn the nut ontop of the wastegate to increase the pressure (kinda to the max like 8-9psi) now it's boosting 6-7psi (manifold)
Old Aug 25, 2003 | 01:56 PM
turbo*s2k's Avatar
Default Re: 7 psi spring and only boosting 4 psi why? (streetrays)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetrays &raquo;</TD></TR><TR><TD CLASS="quote">
Now that's boost leak or some real problem. And as for the 4 psi on supposedly 7 psi spring, I think it's just pressure drop, i'm experiencing the same thing before, but i turn the nut ontop of the wastegate to increase the pressure (kinda to the max like 8-9psi) now it's boosting 6-7psi (manifold)</TD></TR></TABLE>
This is what my friend told me to do when I was having the same problem.
KevinEF7
Oct 7, 2013 10:43 PM
vg7z
Sep 20, 2006 08:27 PM
SPOOLINmatt
Apr 16, 2005 10:13 PM
SOHC_MShue
Mar 14, 2005 03:00 PM
SlowB16
Apr 17, 2002 08:49 AM
