60-1 Garrett specs
Old Aug 4, 2008 | 08:56 PM
T3k C's Avatar
Default 60-1 Garrett specs
I saw an ad selling a Garrett 60-1, these are the specs given to me, what do yall think???TYPO??? TIA
COMPRESSOR SPECS:T04E housing .60 A/R housing
Flow: 53 lbs/min, 678cfm
60 Trim wheel (57 and 50 available, please inquire)
Turbine specs:T3
.63 A/R housing (others available, please inquire)
High Flow 76 trim Stage 3 wheel
Supportable of 500whp!
Old Aug 5, 2008 | 11:29 AM
TheShodan's Avatar
Moderator
Default Re: 60-1 Garrett specs (T3k C)
Everything but the Turbine wheel is good with the 60-1 to get a good powerband (This looks like you got this from a Peakboost ad). THe stage III has always been a mismatch to the 60-1 compressor wheel. If you're trying to keep A/C and PS, the one that you're posting uses a T04S compressor cover, which is rather large to fit, though it will with some grinding of the block, or switching it to face the other direction. depending upon the power, and how you plan to use it (purpose) you may not need anything nearly as big.. Or, you may need something even larger. We don't know your setup, so that will make a big difference.
done
Mar 10, 2005 08:58 AM
Hulkmanj99
Oct 14, 2004 12:49 PM
ModenaTwinTurbo
May 22, 2004 07:14 PM
underpressure02
Feb 10, 2004 07:26 AM
d98clturbo
Jul 29, 2003 06:22 PM
