580cc Injectors Potential
Old Jan 22, 2004 | 07:10 AM
KamikazeSol's Avatar
Default 580cc Injectors Potential
I am looking at upgrading my injectors to a 580cc for my turbo set-up and need some input from people that actually work on turbos alot. I have used the calculators and they all say that for my 300-350 horse goals I would need 650cc plus injectors, but I would like ot not install a resistor if possible and the 580cc are only 285.00 and do not require the resistor box. Any info would defiantely help. the set-up will be a fuly built D16Z6 with a T3/T4 hybrid that wil be run by Hondata.
Old Jan 22, 2004 | 07:21 AM
b18bturbo's Avatar
Default Re: 580cc Injectors Potential (KamikazeSol)
you should be fine with the 580cc of fuel at around 300-350hp with duty cylce around 80-85% running around 50psi of fuel pressure.
Old Jan 22, 2004 | 08:35 AM
omahaturbocivic's Avatar
You could get some precision injectors for that price in almost any size you want. Resistors are cheap and easy.
jdm95
Sep 17, 2009 01:27 AM
Wheelman-CZ
Engine Management and Tuning
Aug 20, 2009 06:49 PM
HybridHatchEF9
Jun 5, 2008 09:05 AM
tegon-gsr
Sep 2, 2004 04:37 AM
DailyBlown
Aug 3, 2003 08:00 AM
