550cc for 400whp is good?
Old Jul 3, 2011 | 12:04 PM
gizmoto2000's Avatar
Default 550cc for 400whp is good?
Ok so I am helping my friend boost his prelude h22 and I would like to give him (for free) some 550cc I have but will it be enough for his 400whp plans?
Old Jul 3, 2011 | 02:10 PM
DC4KiD's Avatar
Default Re: 550cc for 400whp is good?
With a higher base fuel pressure at the rail, it's possible.
Old Jul 3, 2011 | 04:33 PM
Joreus's Avatar
actually i'm in the same boat, interested as well.
Old Jul 3, 2011 | 04:40 PM
lhsv_2004's Avatar
get the bosch 820cc injectors.
Old Jul 3, 2011 | 05:28 PM
wantboost's Avatar
Who is Mr Robot?
^real informative post there noob. Smh
Even If you bump base pressure to 60psi you still won't have enough injector
Old Jul 3, 2011 | 05:41 PM
k20a2delslo's Avatar
Is it possible to get away with 550cc's? Yes with proper tuning, should you, no. It is always in your best interest to have the ability to flood the engine when needed. I know a few tuners that use it as a fail safe. Just my 2 cents
Old Jul 3, 2011 | 05:47 PM
dk=gsr's Avatar
it's possible, just get it tuned or run with a good base map.
Old Jul 3, 2011 | 06:17 PM
cdaiscool's Avatar
I wouldn't. You can probably pull it off at 90% injector duty, but is that smart? Not really.
Do it right, don't regret it later.
Old Jul 3, 2011 | 08:56 PM
What about some 1000cc injectors? Are those too much injector for that kind of power?
Old Jul 4, 2011 | 05:57 AM
DelSolMarine's Avatar
550cc is to small....
believe it or not 100 horsepower to each cylinder in a honda is a ridiculous amount of power... dont cheap out on something as critical as an injector or you will be replacing your motor...
ID750s at the minimum but might as well get ID1000s because sooner or later 400whp isnt going to be enough and this individual is going to want 500whp lol
Old Jul 4, 2011 | 06:51 AM
cdaiscool's Avatar
1,000cc would be fine. Not too much injector for that; it's actually about perfect.
Old Jul 4, 2011 | 07:58 AM
Schister66's Avatar
Man U FTW
550cc injectors will not support 400whp
To get a rough idea of the size you'll need, figure 6cc/whp.
400whp x 6cc/whp = 2400cc total
2400cc / 4 injectors = 600cc injectors at the absolute least
Go with some 720s or even 880s...that way you have room to grow
Old Jul 4, 2011 | 08:09 AM
Spawne32's Avatar
ID750's should be able to take care of you between 400-500hp without a problem of not having overhead
scmil95eg
Dec 31, 2009 04:02 PM
mitchell_2kSiR
Engine Management and Tuning
Feb 6, 2009 09:08 PM
spoon95eg
Jun 21, 2006 07:00 PM
graphic
Apr 7, 2004 11:42 AM
pipes
Feb 27, 2004 07:29 AM
