500 whp fuel setup's
Old Jan 3, 2006 | 03:20 PM
SL0WEGG's Avatar
Default 500 whp fuel setup's
curious to see what you guys are running. im shooting for 400-450 whp and i would like to see what you guys are currently using or what will support those numbers. i was thinking just a walboro 255 hp with some 700cc injectors. would that be suitable for that amount of power? TIA also would the stock ignition be okay for the amount of power? should i upgrade my coil and get like an msd 6al or digital 6 or something of that nature
Old Jan 3, 2006 | 03:40 PM
MaxBoost's Avatar
New User
Default Re: 500 whp fuel setup's (boostedej1)
You got it pretty correct.
Stock everything, just a pump and injectors.
When you buy the injectors, if the price difference isnt too big just go for the 1000cc injectors in case you ever decide to up the boost.
Stock ignition is fine until you have a problem with spark.
Old Jan 3, 2006 | 03:56 PM
SL0WEGG's Avatar
Default Re: 500 whp fuel setup's (MaxBoost)
perfect. thanks
Old Jan 3, 2006 | 04:46 PM
Jared's Avatar
do a quick search in the FI forum archived content for 500whp and 500hp and you'll find more info than you'll ever need.
Old Jan 3, 2006 | 08:32 PM
T4eg's Avatar
a 255pump 780 or 880 injector and stock ignition will be fine at that power level.
Old Jan 4, 2006 | 07:37 AM
SL0WEGG's Avatar
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">do a quick search in the FI forum archived content for 500whp and 500hp and you'll find more info than you'll ever need.</TD></TR></TABLE>
i thought you were being an ***, till i searched the archives , thanks
Old Jan 4, 2006 | 07:47 AM
Bspec18's Avatar
Default Re: (boostedej1)
i'm running close to 700 whp i'm using 2 Aeromotive A1000 Pumps, Fuel Sump,
-10 Fuel Lines, 1600 cc injectors. And for Ignition i'm using CDI, with Coil on plugs. A little bit overkill but i'm happy with the set up
Old Jan 4, 2006 | 09:47 AM
B18C5civic's Avatar
Default Re: (Bspec18)
little bit over kill!!! god damb!!!
Old Jan 4, 2006 | 10:17 AM
SL0WEGG's Avatar
Default Re: (B18C5civic)
yeah i think that may be a bit too much for 450 whp.
KStuned
Jan 3, 2003 04:23 AM
Boostfed
Sep 6, 2002 12:36 AM
speeds
Jun 10, 2002 09:23 PM
jamal-188
Oct 10, 2001 12:03 PM
