5 bolt downpipe with only 4 bolts
Old Apr 25, 2010 | 05:54 PM
bobbyeg6's Avatar
Default 5 bolt downpipe with only 4 bolts
i got a d/p off ebaysssss and its a 5 bolt , the d/p only holds 4 out of 5 the bottom bolt, the head hits the inside of the pipe and i dont know what to do, do you think its ok with only 4 out of 5 and the very bottom missing or will it leak?/
thanks all
Old Apr 25, 2010 | 06:09 PM
ctr32's Avatar
Default Re: 5 bolt downpipe with only 4 bolts
just put some rtv copper sealant on it until you get it fixed
Old Apr 25, 2010 | 07:28 PM
sc34dc4's Avatar
Use an exhaust manifold stud and nut in that spot instead of a bolt. That's what I had to do with my 5 bolt down pipe.
Old Apr 26, 2010 | 04:08 AM
bobbyeg6's Avatar
I was thining both of thos opitions but the studd just clears the bottom of the pipe and no room for bolt or stud head thats the problem.
and second is rvt and torque down
Old Apr 26, 2010 | 04:11 AM
perseverance's Avatar
get a stud, it doesn't have to be long...just enough to get the nut on it and torque it. i don't see why a stud won't work. pics would help. if the stud u get is too long, go ahead and grind it down some. i wouldn't worry about only running 4 bolts, u should be fine.
whatan00b
Dec 2, 2008 12:17 PM
tpot90
Apr 5, 2008 09:46 AM
BoostinEJ1
41
Apr 16, 2006 01:18 PM
StolenTeg
Aug 24, 2005 02:46 PM
Rod.
Jun 3, 2004 07:36 PM
