5 bolt downpipe/ 4 bolt turbo
Old Feb 1, 2005 | 09:19 AM
Phat_GSR's Avatar
Default 5 bolt downpipe/ 4 bolt turbo
I just bought a new turbo, then noticed it has 4 bolt pattern on the exhuast side.
The downpipe that i have is from my drag kit. Is there anyway that i can get around this without buying a new dp??
Old Feb 1, 2005 | 09:25 AM
GDM Z28's Avatar
Default Re: 5 bolt downpipe/ 4 bolt turbo (Phat_GSR)
yes u have ur DP reflanged....
Old Feb 1, 2005 | 09:33 AM
project dc2's Avatar
Default Re: 5 bolt downpipe/ 4 bolt turbo (civicflnum1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">yes u have ur DP reflanged....</TD></TR></TABLE>
wont work very well considering the 4 bolt turbo has a different configuration. if he were to do that i'd be pretty sure he cant access the 5th bottom bolt.
we need to have arturbo show why you CANNOT USE A 4 bolt housing on a drag/inlinepro/revhard/blox manifold ( Pretty much anything designed to use with a 5 bolt)
Old Feb 1, 2005 | 09:49 AM
GDM Z28's Avatar
Default Re: 5 bolt downpipe/ 4 bolt turbo (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
wont work very well considering the 4 bolt turbo has a different configuration. if he were to do that i'd be pretty sure he cant access the 5th bottom bolt. </TD></TR></TABLE>
thes so different? if thats the case cut the dp off right after the a/c comp and have a shop remake that first bend.
Old Feb 1, 2005 | 10:20 AM
Muckman's Avatar
Moderator in Chief
I follow what your saying but I dont see how it could be hard to access 4 bolts rather than 5 on a "drag/inlinepro/revhard/blox manifold" setup. 5 is damn near impossible, 4 has to be easier.
Old Feb 1, 2005 | 01:42 PM
Default Re: 5 bolt downpipe/ 4 bolt turbo (Muckman)
you'd prob ahve to shave the 5 bolt one down a good 1/4 more cuz the 4 bolt version turbo has an extra bit of " lip" to it that you gotta account for .
btw that 4 boolt turbo will not bolt onto your motor the traditional way compressor ( intake side) on the passangerside of the motor.
Old Feb 1, 2005 | 08:15 PM
Phat_GSR's Avatar
no i already figured that it won't bolt up the same way, so i got it mounted the other way.
Speed94
Aug 1, 2008 06:35 AM
tyflip2
Jan 29, 2004 05:04 PM
RudeLude
Jan 3, 2004 12:49 AM
rextec
Dec 11, 2003 05:56 AM
Black DC2
Jun 9, 2003 11:12 PM
