453 WHP 300 torque stock b20/vtec
Old 05-07-2011, 09:03 AM
  #76
vwbased's Avatar
Default Re: 453 WHP 300 torque stock b20/vtec
have a nice day
Old 05-07-2011, 10:58 AM
  #77
93lsv_turbo's Avatar
Originally Posted by vwbased
Nope, just a realistic old fart. I don't like worrying about breaking my engine every time I step on it, which is a lot. I have a non-vtec B20. I broke my ring lands at 18 lbs on pump gas and then noticed hairline cracks in the cylinders.
And no, it was not due to the tune (i don't do girly tunes), just too much stress for the cast pistons and stock cylinders. The plugs, combustion chambers and bearings showed no signs of detonation.
So I rebuilt the engine, installed LA sleeves myself, added CP pistons and Eagle rods. I run 18 psi regularly on pump gas. Full boost by 4k in 1st and I buzz it to 7500+ rpm often. Rear wheel drive means no wheel spin, just lots of acceleration
I'm was just poking a lil fun!
He's vtec head is making him more efficient power then the b20 head. Plus I'm sure going into this he thought about the consequences of making that much power on a stock block.
Old 05-07-2011, 12:14 PM
  #78
VtecKiller32's Avatar
You'll crack the ring lands on those cast pistons first. The telltale sign is more crankcase blowby. Enjoy it while it lasts.
Ive had it boosted almost 2 years now if it was gonna break it would of a long time ago. I boosted it at 109k miles the car now has 117k still strong 380whp....the only thing thats gone wrong was today my clutch started slipping going twin disc now.
Old 05-07-2011, 03:13 PM
  #79
C_Rock77's Avatar
Originally Posted by SkunkedRex
An for you saying the ringlands going an cracking you maybe right.. but I don't care. Cause I melted a piston like 6months ago an orderd $110 doller NPR stock cast pistons off line.
SOOOO!!!!! I'll just do it agian an it will still be a stock motor hitting 10's.
( IT'S ALL ABOUT HAVING FUN AN PUSHING THE BOUNDARYS " TO THE MAX" )
Yeah.. until one of those pieces goes out the exhaust valve, then out and through the turbo.
True story...
Old 06-07-2011, 03:17 AM
  #80
SkunkedRex's Avatar
Going to the dyno soon for a retune an get some more seat time before gainesville import face-off!
Old 06-08-2011, 02:18 PM
  #81
B and B's Avatar
awesome..I give 5 stars. I like the burn out pic.
Do u have some high-dollar axles? Please tell me stock or Autozone.
Old 06-08-2011, 06:56 PM
  #82
allmotorCRX.'s Avatar
Dang thats a nice buget build
Old 06-14-2011, 04:28 AM
  #83
SkunkedRex's Avatar
They are axles from autozone haha.. but I also have a exedy stg2 clutch. It's the street one with the Thick 3 cramic pads w/sprung hub. So I'm very surprised that everything is holding up!
***** UPDATE. *******
I'm pulling the motor out an sending it to goldeneagle to get sleeved an put forged internals an go for a lower number!!
Old 06-14-2011, 02:08 PM
  #84
nonpoint986's Avatar
That seems really low for torque. i dont know if this was asked but what kind of turbo manifold/turbo are you running? i made about 375hp 290 lbs trq with a sc61 journal and inline pro manifold. granted yours is stock. TORQUE FTW!!!
Old 06-15-2011, 01:54 AM
  #85
Benj@mmin's Avatar
Great numbers man, good to see other stock block b20's making some good power and not failing. I just dyno'd my BONE STOCK internal just head studs B20 vtec and made 440 @ only 12psi 330torque on a garrett 60-1. Stopped there to be safe i'm sure 15-18 psi would be impressive. Should have it on the track soon.
Old 06-15-2011, 03:33 AM
  #86
SkunkedRex's Avatar
440 on 12psi? What kind of cams you running?
Old 06-15-2011, 03:42 AM
  #87
SkunkedRex's Avatar
The turbo manifold is custom-built by me, to have a top mount in a 1988 crx small engine bay. No one but one person, boostwork's makes a topmount turbo manifold for a EF chassis..
An the turbo I an out dated ball bearing 61mm. 61-p innovative turbo. Witch the company is called CT TURBO now ( comp turbo)..
I built it to have low TQ. FWD + LOW TQ = traction. Lol. Or what i want to believe.
Old 06-15-2011, 01:35 PM
  #88
Darrell Bs 10SecEG's Avatar
Cool.My other car my rex has a stock B20 long block no block guard and no head studs running 15psi for 1 year now.Im in the works of getting one sleeved and then putting a GSR head on it.Its just starting to blow some white smoke cause the rings are getting worn.But yea,some people on here are running stock blocks and doing good.Its all in the tune and how you keep up the oil changes and maintence on the motor.But im gonna try to make 500 at 15 psi if thats possible on 91 octane.Has anyone made those numbers on 91 octane on here??Just curious.
Old 06-15-2011, 04:08 PM
  #89
Benj@mmin's Avatar
Stock B16 cams, everything in the motor is stock except the head studs.
pasaunde
253
05-02-2020 05:19 PM
SkankzEg616
04-11-2020 07:32 PM
theslugbug
117
01-10-2020 04:43 AM
blackassasin95
11-04-2004 10:38 PM
allout_eg6
04-25-2004 04:40 PM
Quick Reply: 453 WHP 300 torque stock b20/vtec
