453 hp integra (daily driven)
Old Feb 21, 2002 | 07:49 AM
  #26
falcongsr's Avatar
What is this crap?
Default Re: 453 hp integra (boost killz)
Is this Sherbazs' car?? It looks like it and only one I know of in FL in yellow pushing that power. But it really doesn't look like it..could be wrong.
Nick
no its not his car. Sherbaz's racegate is turned horizontal, with a cut in the power steering pump bracket. see pic.
Old Feb 21, 2002 | 10:10 AM
  #27
Lsos's Avatar
Default Re: 453 hp integra (speed_daemon1)
However your reasoning on the pressure levels doesn't make sense.
the pressure should be the same at all points in the oil supply system.
The pressure would be highest at the outlet of the oil pump, and then drop as it goes through tubes (even a straight tube), restrictions, etc....until it flows around to the intake of the pump, when it should be the lowest. It is by no means the same throughout any part of the system.
[Modified by Lsos, 7:13 PM 2/21/2002]
Old Feb 21, 2002 | 10:24 AM
  #28
Giuseppe's Avatar
Default Re: 453 hp integra (Lsos)
pressure and flow are two different things.!
Old Feb 21, 2002 | 01:08 PM
  #29
Captain Save-a-Hoe's Avatar
Nick
Sherbaz's car is actually a Type-r , this car isn't.
Old Feb 21, 2002 | 01:11 PM
  #30
sgT's Avatar
sgT
Default Re: 453 hp integra (Racing Hartless)
Also looks like a B16A, and judging by the torque, it is.
Old Feb 21, 2002 | 02:00 PM
  #31
qwkteg125's Avatar
Default Re: 453 hp integra (sgT)
i don't know about the block, but the head is a b18c, notice the upper radiator hose outlet.
Old Feb 21, 2002 | 02:02 PM
  #32
sgT's Avatar
sgT
Default Re: 453 hp integra (qwkteg125)
Notice it looks like it has a short deck.
that torque is way low
Old Feb 21, 2002 | 02:50 PM
  #33
qwkteg125's Avatar
yeah the torque does look somewhat low considering the power output it is making, but maybe it could be due to limitations of tuning on a stock ecu (at least that what it says on the site that it is using). personally, my eyesight isn't acute enough to see a 7mm difference in deck height, especially in pictures.
here's the guy's dyno chart for those who are interested but too lazy to click the link & read the website:
Old Feb 21, 2002 | 02:57 PM
  #34
Honda Hick's Avatar
Default Re: 453 hp integra (Ray)
From what i've seen non-vtec heads dont have anywhere to tap in for oil. Thats why on LS-VTECs you need to run a line from the back of the block for the VTEC solenoid.
Old Feb 21, 2002 | 03:32 PM
  #35
singlecam screamer's Avatar
Default Re: 453 hp integra (Honda Hick)
well i know who's car that is it's a built gsr motor built by pacific performance,down here in florida,i know the motor is built but as far as anything else i don't know
Old Feb 21, 2002 | 04:29 PM
  #36
SEFIxCivic's Avatar
Default Re: 453 hp integra (DIRep972)
interesting.. that is a mustang dyno, i wonder what it would do on a dynojet..
I wish they would list the mods or some pictures or something..
[Modified by DIRep972, 7:14 AM 2/21/2002]
that is a dynojet dyno.
Old Feb 21, 2002 | 04:39 PM
  #37
DIRep972's Avatar
Smarter than you
Default Re: 453 hp integra (SEFI8LOxCivic)
oops im an idiot! saw the werd mustang and well it was like 2AM when i posted that..
Old Feb 21, 2002 | 04:47 PM
  #38
TurboR's Avatar
New User
I already laid the smackdown on him bout 6-7 times. He is my competitor down here in South Florida. Car is definitely fast and runs mid 11's . I am suppose to run his car again since he is sponsored by a big shop in Florida.
Old Feb 21, 2002 | 05:45 PM
  #39
falcongsr's Avatar
What is this crap?
Default Re: 453 hp integra (TurboR)
cool
Old Feb 21, 2002 | 05:51 PM
  #40
riot's Avatar
453hp? BEH! My friend has a 517whp Integra GSR with a drag kit. I'll have to get some more info like pics after he gets it back from dallas this weekend. I think its at a shop called norwood or something? Home of the 4,000hp integra.
-ryan
Old Feb 21, 2002 | 05:55 PM
  #41
integraty's Avatar
Default Re: 453 hp integra (riot)
So are you guys saying put the oil feeder on the sensor on the back, or like the pic and put it on the VTEC. I'm hearing both still.I'm gonna be doing this on a 94 GS-R with custom setup.
Old Feb 21, 2002 | 06:18 PM
  #42
turbotypeR@SPEC's Avatar
25 Year Member
the torque is low because it is so rich on the bottom.i had a simular set-up and made simular power(434whp and 287 ft lbs).it was so rich from the fuel pressure being so high(fmu)under spool up that it could not be leaned out.if it could be leaned out on the bottom,the torque would be much higher.that is why i now have a power fc and no fmu.
Old Feb 21, 2002 | 07:10 PM
  #43
DIRep972's Avatar
Smarter than you
-ryan
whose your friend? Norwood built his car? they are bad *** but u gotta have alot of loot to shop with them..
Old Feb 21, 2002 | 07:51 PM
  #44
-ryan
But, does your friend work on his own car? The driver of this car does work on it.
[Modified by Racing Hartless, 4:52 AM 2/22/2002]
Old Feb 21, 2002 | 11:07 PM
  #45
Suprdave's Avatar
What's this have to do with anything?
Suprdave
Old Feb 21, 2002 | 11:15 PM
  #46
DIRep972's Avatar
Smarter than you
Default Re: 453 hp integra (Suprdave)
Suprdave
you didnt know u were instantly cooler if u do your own work? geez where have u been!
Old Feb 22, 2002 | 04:52 AM
  #47
therealciviczc's Avatar
Suprdave
Everything. Who cares if you can buy a fast car? Building a fast car is what respectable enthusiasts do, buying a fast car is what old rich guys do once their wives are too ugly to have sex with.
I have zero respect for people who don't build but still brag about their cars.
Old Feb 22, 2002 | 10:51 AM
  #48
Lsos's Avatar
Default Re: 453 hp integra (therealciviczc)
You definately have to give more respect to the guy who built his car than the guy who bought his car from the guy who built it.
Makes sense, right?
Old Feb 22, 2002 | 09:10 PM
  #49
Makes sense, right?
I see that you guys understand my point.
Old Feb 25, 2002 | 01:15 PM
  #50
The dyno was at 22lbs on a non sleeved block, found out on Saturday.
TurBoTeG
Apr 1, 2007 10:10 AM
95dc2teg
Mar 25, 2007 04:06 PM
95dc2teg
Mar 24, 2007 03:30 PM
14
Nov 7, 2006 05:54 PM
Captain Save-a-Hoe
Feb 25, 2002 04:55 PM
