440cc injector limits
Old Apr 5, 2002 | 01:08 PM
  #26
The_Head's Avatar
Default Re: 440cc injector limits (schwett)
I have my injectors maxed out at 260 whp @ the stock pressure.
It also depends on what A/F ratio your car is tuned for.
They tuned mine to run about 12.2-12.5:1 so I wouldnt melt anymore pistons.
So, I'm moving up to 550's when I get the car tuned for 20 psi.
Old Apr 5, 2002 | 01:12 PM
  #27
schwett's Avatar
New User
Default Re: 440cc injector limits (xThexHeadx)
given all this, i wonder why the hell i was at 85% duty cycle, and 90PSI with 370cc injectors to make 220whp. doesn't add up... that's equivalent to 63PSI on the 440s, which you guys are saying will be good for a LOT more than 220whp!
and this was at a not-too-safe 12.5:1 with 13.0:1 in the midrange.
parasitic drag of the SC?
[Modified by schwett, 2:12 PM 4/5/2002]
Old Apr 5, 2002 | 01:41 PM
  #28
sgT's Avatar
sgT
370 @ 90psi = roughly 535cc
440 @ 60psi = roughly 482cc
Old Apr 5, 2002 | 01:47 PM
  #29
schwett's Avatar
New User
Default Re: 440cc injector limits (sgT)
right, by my math, sqrt (90/43) * 370 = 535cc, and sqrt (63/43) * 440 = 533cc. how do you get 482 at 60psi? i get 520cc.
on the other hand, i had to lean it out up top since i couldn't increase the pulse width in the midrange with my previous fueling setup. perhaps now with a standalone i will be able to richen it in the middle and run a slightly lower pressure. 60psi seems a lot to me without having a rr fmu.... it means my static pressure will be around 50psi, which is greater than stock.
Old Apr 5, 2002 | 01:57 PM
  #30
sgT's Avatar
sgT
sorry, 60psi = 520
For some reason I divided by 50 instead of 43....
Old Apr 5, 2002 | 02:46 PM
  #31
93B17A's Avatar
so where do you think i'll be safe at? in terms of fuel pressure, a/f ratio, and boost..... i know there are soooooo many varibles but i'm going to need to know this stuff come dyno time
SpeedRacerEX-R
Jul 29, 2015 08:26 AM
96teggynonVtec
May 15, 2009 11:48 AM
broadheadjohn
Mar 28, 2007 04:20 PM
spoonhatchblack
Mar 29, 2004 06:33 PM
