3in dp and 2 1/2 exhaust
Old Aug 19, 2007 | 07:16 PM
big22's Avatar
Default 3in dp and 2 1/2 exhaust
right now running a full 2 1/2 from turbo back, would it be worth it to get a 3in dp and keep the 2 1/2 exhaust? Really dont want to replace the exhaust if i dont have to. Im running around 300hp if it matters
Old Aug 19, 2007 | 07:45 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
i wouldn't say its worth it, now if you put the 3in downpipe on and took the exhaust off and got it retuned, you'd make more power and have better spool
Old Aug 19, 2007 | 07:59 PM
Dubmekanik's Avatar
Default Re: (tannerLSt)
There was a car we had a hand in a while back, and it seemed to have better spool with the exhaust.....? It didn't really make much sense.
Old Aug 19, 2007 | 08:06 PM
miyagi's Avatar
my 30r spooled faster with the crush bent 2 1/4in exhaust i used for inspection than it did w/ open 3" downpipe... weird.
i wouldn't say it's worth it so to speak, but it won't hurt ... and if you ever go bigger later, it's just one piece you don't have to worry about.
Old Aug 20, 2007 | 03:50 AM
DaveF's Avatar
Default Re: (miyagi)
my street car last year had a 3inch dp/2.5inch exhuast. (450hp 315 tq @18psi on pumpgas from t3/67) my point was to try to keep it more quiet, as opposed to a full 3inch which probably would have been a bit louder.
Old Aug 20, 2007 | 07:22 AM
vtec.dc2's Avatar
Default Re: 3in dp and 2 1/2 exhaust (big22)
i went to 3" from 2.5". as same time i went to 2.5" IC piping, larger air filter and 38mm wastegate from 35mm.. made 30 more whp at same psi. not sure which one contributed more.. but overall isn't much louder and pretty quiet when cruising.
Old Aug 20, 2007 | 08:42 AM
MidwestAutoWorks's Avatar
Default Re: 3in dp and 2 1/2 exhaust (vtec.dc2)
More info on this, Im debating on going to a 2.75 inch exhaust after my 3 inch dp
Old Aug 20, 2007 | 09:20 AM
fmfkid250's Avatar
its fine stock exaust and an eletric cut out is wheres its at anyway
Under_Pressure
Dec 22, 2008 01:14 PM
big-cat
Mar 20, 2007 08:05 AM
b_ron007
Oct 28, 2004 01:49 PM
PrecisionH23a
Jul 27, 2002 11:13 AM
