3bar and uberdata...
Old Apr 28, 2004 | 03:42 AM
scatuli's Avatar
Default 3bar and uberdata...
Well i have read that many people have been having problems running the gm 3bar with uberdata 1.66. Is there anyone who can confirm that it has been fixed.
Willis has a solution but i would rather just hit the 3bar button . so if anyone has any info on this please shed some light.
Old Apr 28, 2004 | 07:15 AM
99blusi's Avatar
Default Re: 3bar and uberdata... (scatuli)
http://www.ecimulti.org/uberdata/
Old Apr 28, 2004 | 08:07 AM
Mad Cow's Avatar
Default Re: 3bar and uberdata... (99blusi)
Old Apr 28, 2004 | 09:34 AM
khoalie's Avatar
great link!
Old Apr 28, 2004 | 10:58 AM
scatuli's Avatar
Default Re: 3bar and uberdata... (khoalie)
Anyone have any personal experience? bluesi thats where i read it was having some problems.
Old Apr 28, 2004 | 02:42 PM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scatuli &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have any personal experience? bluesi thats where i read it was having some problems.</TD></TR></TABLE>
I tuned civicflnum1 on a MSD 3-bar and Uberdata. Only real problem is with very low vacuum situations (low throttle) where the injectors cut off prematurley. Blake is aware of it and is processing the fix. Only other issue is really more of an inconvienience it that the initial mapping of the vacuum portion of the map with a 3bar is waaaaaaaaaaay off. You have to end up dumping alot of fuel in the first 3-4 columns to get a good idle, but like I said, that's just a minor bug that you can work out yourself like I did.
Old Apr 28, 2004 | 04:39 PM
scatuli's Avatar
Default Re: 3bar and uberdata... (VTC_CiViC)
thank you!!! that is the answer i was looking for.i just wasnt sure if a could be corrected by just altering the first 3-4 columns. even though you adjust that you still select the 3 bar map sensor. correct?
Old Apr 28, 2004 | 07:19 PM
VTC_CiViC's Avatar
Yes, select the 3-bar, then do all your injector scaling, then adjust the vac columns to idle the car properly.
Old Apr 28, 2004 | 08:45 PM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khoalie &raquo;</TD></TR><TR><TD CLASS="quote">great link!</TD></TR></TABLE>
Big Phat R
Feb 27, 2007 05:44 PM
Rocks
Mar 3, 2005 05:40 PM
sheissrx
Oct 20, 2004 08:53 PM
RGoose18
May 20, 2004 04:47 PM
streetbreed
Nov 20, 2003 07:14 AM
