.35 too much for 8lbs
Old Oct 7, 2003 | 07:22 AM
steroidguy's Avatar
Default .35 too much for 8lbs
I have my NGK v-power 7's gapped at .35. It feels like im losing power. Im only running 8lbs so im wondering if my plugs are too cold for 8lbs and are gapped too wide. Anyone help?
Old Oct 7, 2003 | 07:28 AM
Boostfed's Avatar
New User
Default Re: .35 too much for 8lbs (steroidguy)
MSD or stock ignition? If stock then get them down to .028 and if you have an MSD take it to .032 at least or possibly .030. Just FYI with my boost levels I go down to .020.Good luck.
Old Oct 7, 2003 | 01:42 PM
steroidguy's Avatar
Thanks a lot boostfed. Stock ignition yes, until i get a BTM. It felt like i was losing power.
Old Oct 7, 2003 | 02:00 PM
racinskittle's Avatar
Default Re: (steroidguy)
does the same apply to Dseries? I set mine at stock gap...1.1mm they're not the v-powers though
Old Oct 7, 2003 | 02:12 PM
Jefnes's Avatar
You won't lose power like poor tuning....
The engine will just cut-out when your coil doesn't have the energy to
light the mix. Two ways to fix it: More energy or less gap.
Stay away from the platinum plugs, these require more engergy than copper plugs.
Jeffrey Atwood
Old Oct 7, 2003 | 05:08 PM
steroidguy's Avatar
Jefnes----could my .35 gap and cold plugs be a reason why my car cuts at the vtec engagement??? If i unplug the solonoid i can redline it on the low cam. But with the solonoid hooked up it cuts at 4800rpm. Made me think its ignition but im not an awesome troubleshooter
Old Oct 7, 2003 | 05:11 PM
Ricey McRicerton's Avatar
Im at the stock gap (.035) and Im having tons of problems...I think I need to drop my gap some.
Old Oct 7, 2003 | 05:23 PM
m R g S r's Avatar
Default Re: (Ricey McRicerton)
Same thing happening with my car right now, it cuts around vtec, a little earlier...Stock plugs, but i do have an msd ignition (in sig) I thought it was the fuel pump so I installed a new one but still the same thing...
Old Oct 7, 2003 | 05:43 PM
Default Re: (m R g S r)
Yeah me too...I put in a Walbro fuel pump before I got my Wideband 02. I also tried gapping my plugs tighter, but its not working out. ( I stand corrected on my previous post..stock is .043...i gapped down to .035)
Old Oct 7, 2003 | 05:44 PM
turbotypeR@SPEC's Avatar
25 Year Member
just buy the zex plugs and you won't have to worry about a gap.i tried ngk and denso at.022 and they still broke up.zex plugs never missed a beat.people will tell you that they are no good but they are full off ****.they have never given me or any of my customers any problems whatsoever.
Old Oct 7, 2003 | 06:39 PM
InTeGrA B18b1's Avatar
Default Re: .35 too much for 8lbs (turbotypeR)
gap it .030
Old Oct 7, 2003 | 06:59 PM
ekb18c's Avatar
Default Re: .35 too much for 8lbs (InTeGrA B18b1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA B18b1 &raquo;</TD></TR><TR><TD CLASS="quote">gap it .030</TD></TR></TABLE>
Boostage
Jul 28, 2006 08:34 AM
dumped_ej1
17
Jan 16, 2006 09:20 AM
nekoabandoned
Dec 27, 2005 09:57 PM
hondaeg8
10
Feb 4, 2005 04:37 PM
Duck Sauce
Jan 13, 2002 06:17 PM
