310cc enough for 250hp???
Old Jul 14, 2003 | 09:06 AM
spooned out's Avatar
Default 310cc enough for 250hp???
just as the title states with use of (greddy kit 18G) blue box need input ASAP!!!!!! or should i go with 440 and hondata? help ASAP thanks...
Old Jul 14, 2003 | 09:07 AM
romeo619romeo's Avatar
Default Re: 310cc enough for 250hp??? (spooned out)
ive asked this.. already... you need bigger injectors and hondata... well some sort of stand alone...or hack...im in the same boat as you
Old Jul 14, 2003 | 09:47 AM
falcongsr's Avatar
What is this crap?
310cc injectors with my greddy kit, with opened up exhaust = 100% duty cycle on my injectors before redline. not good.
Old Jul 14, 2003 | 10:00 AM
gitwidit's Avatar
Default Re: 310cc enough for 250hp??? (falconGSR)
440's w/ hondata, 251whp I'm at 80-85% injetor duty on my datalogger.
Old Jul 14, 2003 | 10:03 AM
Yeah thanks for your input ill get some rc 440cc, but till i get hondata will the blue box work okay with 440cc in the mean time?
Old Jul 14, 2003 | 10:21 AM
b16ahybrid's Avatar
Default Re: (spooned out)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooned out &raquo;</TD></TR><TR><TD CLASS="quote">Yeah thanks for your input ill get some rc 440cc, but till i get hondata will the blue box work okay with 440cc in the mean time?</TD></TR></TABLE>
Nope, the 440's will dump to much fuel. The blue box is calibrated for 310c injectors.
Old Jul 14, 2003 | 10:41 AM
mos's Avatar
mos
Default Re: 310cc enough for 250hp??? (GITWIDIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GITWIDIT &raquo;</TD></TR><TR><TD CLASS="quote">440's w/ hondata, 251whp I'm at 80-85% injetor duty on my datalogger.</TD></TR></TABLE>
What fuel pressure were you running?
Old Jul 14, 2003 | 10:57 AM
DeepSi's Avatar
Default Re: (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">
Nope, the 440's will dump to much fuel. The blue box is calibrated for 310c injectors.</TD></TR></TABLE> True, the maps in the blue box are designed for 310cc. If you use 440cc, to much fuel will be dumped, causing your car to stumble really bad.
Old Jul 14, 2003 | 11:01 AM
FredoSP's Avatar
Default Re: (DeepSi)
hondata
Old Jul 14, 2003 | 10:59 PM
if i get hondata what size injectors would you suggest for about 220-250hp no more since its still stock block and head.... i do have a set of h22 96 prelude injectors laying around could i use those?
Old Jul 15, 2003 | 09:30 PM
b16ahybrid's Avatar
I would recomend 550cc injectors.
the prelude injectors are 270cc i believe
Old Jul 15, 2003 | 09:41 PM
vtec.dc2's Avatar
this is with 255hp intank fuel pump? if so, then what fuel pressure? and what rpm for peak horsepower?
Old Jul 15, 2003 | 09:44 PM
vtec.dc2's Avatar
i'd get high pressure intank fuel pump and fuel pressure regulator along with injectors and hondata.
Old Jul 16, 2003 | 05:14 AM
gitwidit's Avatar
Default Re: 310cc enough for 250hp??? (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
this is with 255hp intank fuel pump? if so, then what fuel pressure? and what rpm for peak horsepower?</TD></TR></TABLE>
255lph intank 43psi static (if i recall correctly) 7,300 rpm.
80-85% injector duty was seen on my d16 while spraying a 90 shot dry w/ hondata nitrous controls, that may have some effect on duty cycle.
showty
Oct 9, 2003 10:02 PM
spooned out
Jul 11, 2003 08:39 PM
roydogg
Jun 19, 2003 08:44 PM
Boosted GSR
Apr 10, 2003 12:07 PM
Shaun K
Apr 19, 2002 05:48 PM
