310cc or 450 cc
Old Jul 6, 2004 | 06:42 PM
JDMJONES's Avatar
Default 310cc or 450 cc
I am planning on boosting 7psi. Are 310cc injectors OK or will I need bigger?
Old Jul 7, 2004 | 01:02 PM
eric98gsr's Avatar
Default Re: 310cc or 450 cc (JDMJONES)
Hell at 7 psi 310cc should be fine. What kind of turbo do you have? Greddy uses 310cc but it's a smaller turbo. A T3/T4 you might get away with it but I'd go with 440cc.
Old Jul 7, 2004 | 01:14 PM
Pimp Joose's Avatar
Default Re: 310cc or 450 cc (eric98gsr)
I would run 450's just to be safe.
Old Jul 7, 2004 | 05:22 PM
JDMJONES's Avatar
Default Re: 310cc or 450 cc (Pimp Joose)
thanks guys. I have a 96 Del Sol. What would I need for DSM injectors or should I just go with RC's.I have a T3/T4.
Old Jul 7, 2004 | 06:53 PM
snailpoweredEK's Avatar
what kind of whp numbers are you hoping to reach?
Old Jul 7, 2004 | 07:00 PM
AspectIndustries's Avatar
Default Re: 310cc or 450 cc (snailpoweredEK)
go with 450cc+ for the long run. Be safe. Research. -
Old Jul 7, 2004 | 07:01 PM
dunkd's Avatar
ive read that DSM 450's flow about the same as RC310's... go with some RC440's
Old Jul 7, 2004 | 09:55 PM
Blueprint's Avatar
Default Re: (feri0)
you have to run 310cc unless you have an engine management or afc hack.
Old Jul 7, 2004 | 10:22 PM
Sketch_hs's Avatar
Default Re: (Blueprint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blueprint &raquo;</TD></TR><TR><TD CLASS="quote">you have to run 310cc unless you have an engine management or afc hack.</TD></TR></TABLE>
WTF?
bigger injectors are needed for boost with the hack and engine management (UBERDATA is FREE!!).
If you run a shitty FMU then you don't need big injectors. But don't do that, use REAL engine management like UBERDATA or if you want to pay hondata, aem ems....
for injectors, bigger is better up to a point. I'd rather have 450ccs than the 310ccs. Either way you have to completly retune.
Good luck
Old Jul 7, 2004 | 10:34 PM
Blueprint's Avatar
Default Re: (Sketch_hs)
WTF? stock ecu cant control 450cc, unless you have a uberdata, hondata or AFC or any other engine management... if your running fmu the biggest you can run is stock-310cc. if you read i put "UNLESS" you have engine management
(ex, uberdata, hondata, or AFC hack)
tinymotor22
Apr 16, 2008 06:48 PM
GTEC913
Mar 8, 2008 07:49 PM
nicko360
12
Mar 6, 2007 12:33 PM
menappi
11
Mar 25, 2005 12:25 PM
plusONE jboy
Mar 26, 2004 11:23 AM
