3 simple questions...
Old Sep 13, 2003 | 01:07 AM
raene's Avatar
Default 3 simple questions...
a) What oilpan fits a JDM B16A engine? I hear LS but isn't the GSR baffled? I think I dented my pan on a logging road
b) What size fitting is good for a turbo oil return line? I think I'd want a threaded fitting rather than barbed, if that's possible. If it needs to be said I'll be running a mild t3/t04e (haven't chosen yet), not sure if that affects the size of the oil return line.
c) Can someone please post a pic of a fitting welded to a B16A oilpan so I know where to have it welded & the angle?
Sorry for the n00b questions... I don't plan on going turbo for quite a few months but if I'm replacing the oilpan I might as well get that fitting installed while the pan's already out
Old Sep 13, 2003 | 05:47 AM
Acura_I-RS's Avatar
Default Re: 3 simple questions... (raene)
ok, not sure about 1, but 2:contact flamenco_t on here for any oil feed/return questions(tell him i sent ya!)
3:you will want to figure out your exact setup first, most setups are different, so its hard to tell where to put it really, usually, more towards the drivers side on the oil pan. if you want pics, SEARCH is your friend!!! hope i helped!!
Old Sep 13, 2003 | 10:18 AM
raene's Avatar
Default Re: 3 simple questions... (Acura_I-RS)
Well, I DID search... 40 threads of oilpan questions. No one answered it conclusively, that's why I asked.
I found some pics yes, but they were pics asking "do you think this should be OK" not "take a look at my oilpan fitting, it's perfect" so I don't exactly want to use them for a guideline
cfwthb_94
Mar 19, 2010 12:22 PM
CTR_B
Apr 15, 2008 11:00 AM
88da3
Feb 1, 2006 03:47 PM
94lsboost
Nov 28, 2004 03:33 PM
Carp
May 8, 2003 04:29 PM
