3 inch exh/boost spike
Old Feb 28, 2002 | 02:53 AM
teamrocket si's Avatar
Default 3 inch exh/boost spike
Does a larger exhaust cause boost spike? Why?
Old Feb 28, 2002 | 03:29 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: 3 inch exh/boost spike (teamrocket si)
Only those manifolds that have the wg port on a single runner. For example, the Drag has the wastegate port on runner #1. The wastegate cant keep up with the pressure so you get boost spikes. Ive only experienced this with the drag manifold. I have a rev-hard and 3" exhaust and no boost spikes because the wg port is mounted inbetween the 1st and 2nd runner.
Now a good set up I recomend with the drag is keeping the 2.5" downpipe with a 3" exhuast. Ive seen good gains with this and you dont have boost spikes.
art
Old Feb 28, 2002 | 05:09 AM
dragnGSR's Avatar
Default Re: 3 inch exh/boost spike (Arturbo)
I think I may use your recommendation Art. I was thinking about getting a 3" downpipe, but maybe I'll just stick to getting a 3" Thermal instead. I should be getting my car back this weekend and then will be adding a boost controller. I should be running around 10-12psi and I really don't need it boost creeping.
Old Feb 28, 2002 | 05:24 AM
austrian type-R's Avatar
Art, I don´t get it.
When I look at my DRAG manifold I can see 2 runners (cyl 1 + 2) are leading to the wastegate port. Perhaps you are talking of an old style Drag mani?!?!
Old Feb 28, 2002 | 05:32 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: 3 inch exh/boost spike (austrian type-R)
Old Feb 28, 2002 | 02:16 PM
dragnGSR's Avatar
So that would be over one runner?
Old Feb 28, 2002 | 02:18 PM
cyan1de's Avatar
Default Re: 3 inch exh/boost spike (dragnGSR)
correct, it's over runner 1 only.
Old Feb 28, 2002 | 04:08 PM
DLB1994's Avatar
Default Re: 3 inch exh/boost spike (cyan1de)
this type dont spike with a 3inch down pipe
Old Feb 28, 2002 | 04:10 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: 3 inch exh/boost spike (DLB1994)
I would hope not..lol
art
Old Feb 28, 2002 | 04:15 PM
dustin's Avatar
Elephant trunk manifold!
drag gen 2 owning you! haha
Vtec-G2teg
Mar 22, 2010 09:33 AM
D15Bbigred
Jul 1, 2006 12:40 AM
Ryceboi318
Feb 2, 2005 12:15 PM
RedTegLS
Feb 4, 2004 04:22 AM
DD_JonnyLee
Feb 3, 2003 10:04 AM
