3 bolt Down pipe flange needed searched cant find.
hey wassup im in need of a 3 bolt down pipe flange for a mitsubishi turbo, ive searched and checked a couple of sites like kteller, and rre if anyone and point me in the right direction itll be greatly appreciated thanx.
This is a mitsubishi 15t turbo off a saab
this is the bolt spacing distance
this one is the tag, with model and serial numbers.
Also is this fmic any good.
ok so far i have the turbo which is the 15t pictured i have a greddy manifold to which the turbo bolts up to i have the greddy fmic and i have a set of 2nd gen dsm injectors and a honda resistor box and i have charge pipe with a turbo xs rfl bov, also have a p28 socketed awaiting uberdata, complete 3 inch magnaflow stainless piping all the way down to a magna flow oval, and all i think im missing is the rest of the IC pipes the, downpipe, internal mitsubishi wastegate, and obd2-1 conversion harness.
thanx for any help.
also if a mod feels this belongs in the welding fab section by all means move it. thanx
Modified by 92hatchZ6 at 11:12 PM 6/7/2005
thanx for any help.
Re: 3 bolt Down pipe flange needed searched cant find. (92hatchZ6)
that going to use a donut style gasket? its nto flat is it?
you dont want to cut it off and go with something more common? haha
Re: 3 bolt Down pipe flange needed searched cant find. (KTeller8)
hey i wouldnt mind cutting it off as long as i can get a standard downpipe made for it without that donut gasket. thanks for replyin
Why don't you measure the distance between the bolt/bolt holes and see if it matches any flanges or flange gaskets at the store? If so, just pull out the donut gasket, then use a flex section on the downpipe.
Re: 3 bolt Down pipe flange needed searched cant find. (USE2B16A)
cool thanx ill try that out, but what kind of flex section are u talking about braided flex pipe or that flex that a complete pipe but bends easy.
