3 bar map sensor, what is the resistance?
Old Sep 23, 2006 | 09:27 AM
sleeprhatch's Avatar
Default 3 bar map sensor, what is the resistance?
I'm trying to check to see if I have a bad 3 bar map sensor, anybody know what the resistance is? I did a search already and can't find it. I also checked the voltage going to the map sensor....everything is fine. I have the vaccuum directly to the intake manifold with the other line. :gotme:
Old Sep 23, 2006 | 09:46 AM
Default Re: 3 bar map sensor, what is the resistance? (sleeprhatch)
http://autorepair.about.com/cs...6.htm
Old Sep 23, 2006 | 11:43 AM
playahwitgame's Avatar
what makes you think you have a bad map sensor? or is it just to be sure?
Old Sep 23, 2006 | 11:49 AM
well I currently have the stock map sensor in it. It runs fine then when I unplug it and connect the gm 3 bar map it runs super rich and crappy. Idles like ***. Just to make sure I connect back the stock map.....bam it runs normal.
Old Sep 23, 2006 | 11:56 AM
IndySporty's Avatar
is your computer programmed to read the 3 bar? If not it's going to be wrong and run like crap because it is calibrated differently than a honda map sensor which only ranges up to about 10 PSI maximum. Your 3 bar reads over 3 times that much pressure.
Old Sep 23, 2006 | 12:04 PM
I didn't know that.
young geezer
Aug 1, 2009 12:44 PM
KRWTEK1
May 28, 2007 12:32 AM
NA JDM GSR
Oct 29, 2006 08:38 AM
turbolshatch
Feb 2, 2006 06:06 AM
CiViC SiR
Jun 25, 2003 04:56 PM
