is 3 bar map sensor needed with hondata?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverbeast »</TD></TR><TR><TD CLASS="quote">1. search
2. if you plan on running more than 11psi</TD></TR></TABLE>
like he said. Stock map sensor is good up to 11psi. After that you have to wire in a 3bar which arent that expensive
I just bought an SVE 3-bar map sensor from Lightning Motorsports
http://www.lightningmotorsport...c.htm
$75 Shipped for HT members
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthame1 »</TD></TR><TR><TD CLASS="quote">I just bought an SVE 3-bar map sensor from Lightning Motorsports
that's pretty expensive
i bought mine from summitracing for 55 shipped.
</TD></TR></TABLE>that's pretty expensive
thats just the map sensor.....the correct weathertite connectors that come with the SVE kit are pretty expensive and difficult to find. I researched b/f I bought it.
That connector is a really common one and used on a lot of GM plugs. Just go to a pull it yourself yard and you got yourself a plug.
