3 bar map sensor
I guess the 3 bar MAP tops out at 5v @ around 30psi? You'd have to trim out more voltage than the AFC can, if that's the case. You'll need to add an additional voltage splitter or something inline before the AFC...
honda ecu wants a 2bar map sensor. Unless you get a hondata or aem ems (or some other standalone) you will have a hell of a hard time making your car run right.
If you really need more boost then 12psi...stop messing with the afc hack and step up to the hondata or aem ems.
liam
liam
liam
