3.5 turbo
Old Oct 24, 2010 | 09:34 PM
455bird's Avatar
Default 3.5 turbo
I know I’m out of my kind of forum but I need some tuners help. I have a 2002 3.5 Honda out of an odyssey in a sand rail. The motor has a header, K&N and I run a 3.2 Acura ECM. This combo runs great but it’s time for some more power. Most people in sand rail run a turbo on them with 50/50 race gas. Do most of the street guys run race or is there a way to run a turbo without race? I’m looking for around 4 to 6 psi of boost. What other mods work with this motor to get more power out it. Thanks
Old Oct 24, 2010 | 09:45 PM
TurboSo.African's Avatar
Default Re: 3.5 turbo
It is not necessary to run any race gas in there, but it will help with detonation. At 6 lbs you should not need to run any race gas, just be sure to have a intercooler the is adequate size, especially if you are going to be running wide open, as you do in the dunes. I have a D16 with turbo in my rail and run it flat out at 7 lbs, no intercooler, but I do put one bottle of Octane booster in or Toluene
Old Oct 25, 2010 | 08:17 AM
paulzy's Avatar
Where are you located? How long do you run the car at a time? What size tank you have? E85 would be a great option for you as well if you have it readily available where you're located.
Old Oct 25, 2010 | 08:20 AM
del_sol_freak's Avatar
j32a.com is a good forum to referance
Old Oct 25, 2010 | 03:22 PM
E85 is a great option, but you will have to go to a bigger injector and possibly a bigger pump, depending on a number of things.
NirVTEC
Apr 27, 2009 10:17 AM
.dave
Sep 9, 2005 04:51 AM
myinvestedagony
Feb 11, 2004 07:43 AM
pkripper
Aug 23, 2001 03:37 PM
