25+ pounds on Ls
Old Oct 5, 2001 | 09:47 AM
T.Werd's Avatar
New User
Default 25+ pounds on Ls
I plan to run 25+ pounds of boost with race gas at the track only. On the street I might run 15 pounds. Here is my set up tell me if you think I can meet my goal.
Drag turbo kit w/tial
NGK 7 series plugs
Aem adjustable fpr
holly 255LPH In tank Fuel pump
clutchmasters stage 4 or suggestions
Greddy profec B w/ switch
Autometer boost gauge
Autometer a/f meter
greddy egt gauge
Autometer oil pressure gauge
Autometer fuel pressure
Skunk2 coilovers stiff rear
quaiffe
Zdyne Gold w/3bar map sensor
MSD 6aL
msd blaster 2 coil
msd pro cap
RC 720cc injectors
Bulletproof block
Head (cams, port/polish, valve springs, retainers)
Venom Intake manifold
Throttle Body
thanks
Old Oct 5, 2001 | 09:53 AM
dragonsmp's Avatar
New User
Default Re: 25+ pounds on Ls (10sec.civic)
Stock internals??? Stock compression??? Ya... you'll bet able to get one run in before the **** goes POP
Old Oct 5, 2001 | 10:02 AM
PureTeg420's Avatar
Default Re: 25+ pounds on Ls (dragonsmp)
read his list again,it says bulletproof block, and a deckout head. With some good tuning I could see this as a possiblity, but your gonna need lots of time and money to make it happen.
Old Oct 5, 2001 | 10:08 AM
FAST94GSR's Avatar
New User
Default Re: 25+ pounds on Ls (PureTeg420)
after all is done plan on spending all together about 15 grand.
Old Oct 5, 2001 | 10:32 AM
T.Werd's Avatar
New User
Default Re: 25+ pounds on Ls (FAST94GSR)
I have figured 11000 dollars at this moment but that isnt figured in any tuning. I knowq that stuff will come up that i will need. thanks for the responses. What kind of times do you guys think that I could see on slicks in a crx street car?
Old Oct 5, 2001 | 10:53 AM
rtype11's Avatar
Make sure if you get the holley pump to order part number 916 and not 906, the 916 is meant for forced induction. they are still both 255lph.
I run one intank and y blocked into a big bosch close to the rail when I go over 15lbs.
My sig best time is not current I am well into tens now and run an LS with similar specs to what you will build but my sleeves are stock and run DFI. No problem running 20+ lbs, one good detonation will spoil the show.
Old Oct 5, 2001 | 01:54 PM
T.Werd's Avatar
New User
Default Re: 25+ pounds on Ls (rtype11)
I think that I am going to get a beefier fuel pump because i have been told by several people that it wont handle it. rtype11 could you give me more details on your set up. My email is vipe266618@aol.com.
Old Oct 5, 2001 | 02:08 PM
dragonsmp's Avatar
New User
opps... didn't see that in his list... Sorry!
Old Oct 5, 2001 | 02:09 PM
T.Werd's Avatar
New User
thats ok
tthame1
Texas -OK -LA (Sales)
May 4, 2007 06:27 AM
tthame1
May 4, 2007 06:26 AM
GForceInteg
May 26, 2003 09:46 AM
2000Si-at-UK
Sep 8, 2002 04:45 PM
dragsol
Sep 17, 2001 03:11 PM
