22re 4X4 T3 power :-)
Old May 11, 2003 | 06:57 AM
Tinker219's Avatar
Default 22re 4X4 T3 power :-)
I just picked up an 89 Toyota Pickup for $500. I was told the engine was locked up from overheating.
Well, I unloaded it from the trailer and decided to hit the key. It turned over! Im thinking at most I will need a headgasket because it sounded like there was no compression.
In any case, anybody have a 22re laying around? With my luck, the engine is history, so Im still looking for another one.
Im gonna slap a lil .38 T3 on there, fmu, and run 3-5 psi. Bosch BOV. I wanna be able to make it up any two track w/out running out of steam
heres some pics:
Modified by Tinker219 at 11:35 AM 5/11/2003
Old May 11, 2003 | 09:01 AM
t04s's Avatar
Default Re: 22re 4X4 T3 power :-) (Tinker219)
Wow tinker, you live in the boondocks.
Old May 11, 2003 | 09:04 AM
93LSivic's Avatar
22R's are stout motors.....but they've been known to have hg problems, hehe.
Boost the hell out of it. Looks to be a fun project. I had a friend that had an older Toy 4x4 with 22r and we used to abuse the **** out of it.
Old May 11, 2003 | 09:12 AM
Full-Race Geoff's Avatar
do some research... its not what you think it is. Check the timing chain guides.
A pic of my 22r truck
im running a standalone we built and a t3t4 57 trim
Old May 11, 2003 | 09:17 AM
Phoenix GSR's Avatar
I dont think you can just toss an fmu on a mass air motor
Old May 11, 2003 | 09:20 AM
Default Re: 22re 4X4 T3 power :-) (Phoenix GSR)
you can, and it will work, but it sucks as usual. Also its a mass air meter, it doesunt use a wire, it uses this antiquated spring loaded flap thing, its really a crappy system
Old May 11, 2003 | 09:22 AM
TheShocker's Avatar
22REs are great. SuperT made ~500 WHP on his before the 2JZ went in.
-Seth
Old May 11, 2003 | 11:09 AM
hulkhb's Avatar
Default Re: 22re 4X4 T3 power :-) (TheShocker)
Good deal Tinker, i have the 2wd drive version with 186K miles on it and it runs good.
Old May 11, 2003 | 11:15 AM
93LSivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShocker &raquo;</TD></TR><TR><TD CLASS="quote">22REs are great. SuperT made ~500 WHP on his before the 2JZ went in.
-Seth</TD></TR></TABLE>
He would have made more power if the manifold was a Full-Race product
Old May 11, 2003 | 01:22 PM
Tinker219's Avatar
Default Re: 22re 4X4 T3 power :-) (FFgeoff)
So should I just use the stock MAF sensor? I was just going to route the turbo inlet through it, and call it good. I would think that the small amount of added air wouldnt affect anything too much.
Get some more pics of your truck up Geoff, that one didnt work...
Tinker219's Avatar
Default Re: 22re 4X4 T3 power :-) (t04s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t04s &raquo;</TD></TR><TR><TD CLASS="quote">Wow tinker, you live in the boondocks. </TD></TR></TABLE>
yup...hehe, nothing else for me to do, except cut and weld
Old May 11, 2003 | 04:20 PM
boosted3g's Avatar
nice steal for 500 bucks. 22re's are a dime a dozen youll have no problem finding one. My 89 has the shitty 3.0 v6 in it. Yeah the one that dont idle for ****, has all the recalls, and you cant repair anything. Changing the oil takes a good hour.
Old May 11, 2003 | 05:01 PM
SikofFalln's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FFgeoff &raquo;</TD></TR><TR><TD CLASS="quote">do some research... its not what you think it is. Check the timing chain guides.
What the Funk? That thing is awesome where can I see more of it?
Old May 11, 2003 | 05:05 PM
integra-modder's Avatar
very cool tinker....
i guess there is a benefit to living in the middle of bumble ****...
Old May 11, 2003 | 05:14 PM
Tinker219's Avatar
Default Re: 22re 4X4 T3 power :-) (integra-modder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder &raquo;</TD></TR><TR><TD CLASS="quote">very cool tinker....
I have some nice wheelin territory around here too. I tell you what, the whine of the turbo and the pop of the BOV will make the people up here on the trails run for cover...
Old May 11, 2003 | 06:18 PM
Joseph Davis's Avatar
Man, that is a great deal for a clean body and 4WD drivetrain.
22R's labyrinthine timing chain tensioners/guides or HG are valid opinions. You're supposed to pop the head off when putting a timing chain on those motors, and I know people who just l-i-f-t it a little and try to get by without a proper replacement. I also know people who can pop the cam gear on + off without removing the head, or so they claim - good luck trying.
I think .38 AR will be really crappy, go with a .48 if you want low spool. With .48 turbine, and regular T3 compressor of some nature, on a 2.4 liter you'll start spooling at ~1000 if there's load on the engine.
There's a guy locally running a GM 749 ECM on his T3 Toyota truck, his name is Jon, he might be able to advise you at little: galadar@worldnet.att.net
You might look into running dual Toy VAFs (Vane Air Flow - it's not a MAF as pointed out earlier) with an AFC like the Supra guys do to fit in more boost.
Old May 11, 2003 | 06:44 PM
Tinker219's Avatar
Default Re: 22re 4X4 T3 power :-) (J. Davis)
cool, thanx for the help dude...
Old May 11, 2003 | 06:53 PM
lazerus's Avatar
hrmm... i'd say swap in a 7m-GTE. http://www.yotapower.com
Old May 11, 2003 | 07:14 PM
Default Re: 22re 4X4 T3 power :-) (lazerus)
On the engine swap into Toyota truck subject, there's supposed to be a guy who runs around town with a lightly wrecked in the front mid-80s Toyota 2WD pickup, hood held shut with bungee cords, and a lightly modded 2JZ.
The rumor mill claims low 11's, you know what the rumor mill is worth, but I wouldn't be surprised if it were true. The non-4WD doesn't weigh anywhere what a Pigsupra does.
Old May 12, 2003 | 02:52 PM
TheShocker's Avatar
Default Re: 22re 4X4 T3 power :-) (93LSivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">
He would have made more power if the manifold was a Full-Race product </TD></TR></TABLE>
Yeah he probably would have made 1700 HP thanks to the collector design and the 304 stainless steel weld els.
-Seth
Old May 12, 2003 | 03:04 PM
senpai's Avatar
these motors are good for turbo? My dad has the 2WD version, does that matter?
Old May 12, 2003 | 03:42 PM
TheShocker's Avatar
Default Re: 22re 4X4 T3 power :-) (maztur)
Yep and they have great rear ends too. Handled 500 WHP for two entire seasons without a single breakage.
Old May 12, 2003 | 03:54 PM
senpai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShocker &raquo;</TD></TR><TR><TD CLASS="quote">Yep and they have great rear ends too. Handled 500 WHP for two entire seasons without a single breakage.</TD></TR></TABLE>
hmmm ... *evil grin*
Old May 12, 2003 | 05:08 PM
rOby's Avatar
1jz or 2jz...a 7mgte is ok, prone to hg problems. ive never seen one in person that has put down over 450.
Old May 12, 2003 | 06:59 PM
Default pics of trucks
the stock axles are badass. I actually run the slightly beefier (and wider) axle out of the toyota tundra which uses a 30 spline shaft, which is actulaly shared with a Dana 60. The housing already comes with a pretty beefy truss from the factory, and serious trussing is helpful, but definately not necessary. daves 22r truck is crazy fast tho, he must have huge ***** running on stock leafs like that... thats just scary/dangerous. did he have headwork?
a sickass ranger
not-so-recent pics of my truck &lt;insert 32 gal fuel cell and a lot more tubes&gt;
