22psi ignition cut out....
Old Sep 20, 2010 | 11:13 AM
sean082's Avatar
Default 22psi ignition cut out....
I have a built gsr turbo tuned on C16. Car was making just over 500whp on stock ignition components. Dyno tuned great, no issues, made 5-10 passes no issues. 11th pass in the water box at part throttle car was cutting out, almost sounded like detination. I made the pass, in 4th gear car cut out completely almost like boost cut.. I changed the distributer, spark plugs, tightened the gap, new fuel... Problem is getting worse. Tune looks good on the computer/chip, had it back on the dyno, could not duplicate the problem...
Any thoughts?
Old Sep 20, 2010 | 01:22 PM
jdm602's Avatar
Default Re: 22psi ignition cut out....
maybe its just blowing out the spark...whats your gap?
Old Sep 28, 2010 | 01:36 PM
sean082's Avatar
.0015
Old Sep 28, 2010 | 02:03 PM
TheShodan's Avatar
Moderator
Sounds like ignition is going. Stock can only last so long based upon the use (and subsequent abuse) of the ICM and Ignitor. Might be time to upgrade if you're going to continue to put the ignition through this kind of pace.
Old Sep 28, 2010 | 02:11 PM
sean082's Avatar
Thats what I was thinking also, I replaced the diz and it didnt make a difference.
Old Sep 28, 2010 | 02:34 PM
TheShodan's Avatar
Moderator
You need more than that now... its time for UPGRADED ignition not just "dizzy swaps".
Old Sep 28, 2010 | 09:35 PM
jetspeedz's Avatar
Get a M&W kit from T1 and save yourself the headache with blown ICM's. Good luck
Old Sep 29, 2010 | 09:46 AM
welfarepc's Avatar
one time i thought i had the same problem... it would be fine when cold, but once it got warm it would start to do what i thought was ignition cut or some kind of ignition problem.
turned out to be valve float and i busted a retainer and dropped a valve.
Old Sep 29, 2010 | 09:52 AM
Muckman's Avatar
Moderator in Chief
Try a new OEM igniter/coil first.
You mean .015" not .0015" I hope
Old Sep 29, 2010 | 11:31 AM
Bizzle5OH3's Avatar
What kind of map sensor do you have?
sean082
Sep 20, 2010 11:35 AM
SpoolnByYou
Mar 22, 2006 08:13 AM
XX Boosted Si XX
Dec 7, 2005 02:50 PM
boostin GSR
Jun 12, 2003 11:44 AM
