2 step
Old May 24, 2006 | 12:08 PM
joker4096's Avatar
Default 2 step
what exactly is this? i did search but only found whare to buy. dont understand what they mean by a 2step. its like a rev limiter right?
Old May 24, 2006 | 12:23 PM
a1320addict's Avatar
Default Re: 2 step (joker4096)
I can only speak on my own experiences with the 2-step built into Neptune.
You rev to whatever RPM you would like to engage the 2-step at, hold it at that RPM and then floor it. You then bounce off a limiter at that RPM.
Useful in consistent launches, building boost off the line, etc.
Hope that helps.
Old May 24, 2006 | 01:29 PM
alpha's Avatar
It's basically a rev limiter used to launch at a desired RPM and/or boost level. You can cut fuel, spark or both. If your EMS is capable of it you can retard the timing. I was able to make 19lbs - 21lbs at 4,500RPM with the timing at -10 degrees I think it was. with a car I tuned. Video is below.
RIGHT CLICK SAVE TARGET-AS
Modified by 0x64 at 5:54 PM 5/24/2006
Old May 24, 2006 | 01:33 PM
TurboCoop's Avatar
Default Re: 2 step (0x64)
theres no 2-step in the vid??? ^^^ its just his car idling
Old May 24, 2006 | 01:42 PM
Importracer_001's Avatar
What kind of wastegate spring were you using on that setup?
I heard the amount of boost you build depends on the wastegate spring is this correct?
Because when I set my 2step in S300 at 5000rpm I make only about 7 psi boost with a 7.25 psi wastegate spring.
Old May 24, 2006 | 01:54 PM
alpha's Avatar
Default Re: 2 step (TurboCoop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCoop &raquo;</TD></TR><TR><TD CLASS="quote">theres no 2-step in the vid??? ^^^ its just his car idling</TD></TR></TABLE>
Try now
Old May 24, 2006 | 01:55 PM
alpha's Avatar
Default Re: 2 step (Importracer_001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Importracer_001 &raquo;</TD></TR><TR><TD CLASS="quote">What kind of wastegate spring were you using on that setup?
Because when I set my 2step in S300 at 5000rpm I make only about 7 psi boost with a 7.25 psi wastegate spring.</TD></TR></TABLE>
That's true but with their engine management I could control how much boost it built with the boost control
Old May 24, 2006 | 01:57 PM
So If I have a MBC set at lets say 14 psi I should be able to build more boost than what I am building now with the S300?
charlie_sohc
May 19, 2008 04:04 PM
twenty
Jun 27, 2005 02:04 PM
b00stedbyFastrax
Dec 10, 2004 03:43 PM
turbospool
Jun 17, 2003 01:20 AM
