car hit rev limits/boggs at 4100K
Old Jan 6, 2008 | 08:01 PM
charlie_sohc's Avatar
Default car hit rev limits/boggs at 4100K
ok i been having a issuse here, car boggs like hitting a rev limiter at 4100K, setup build d16a6 with z6 head on boost @20 lbs, yeah its was tune hitt air fuel around the low 12:1, no cel, we change map, tps, distr, and check the timing base at 16 btdc, around 4100k rpm is 22-26 timing and it still like it is hitting a rev limiter and it chokes. any help??
Old Jan 6, 2008 | 09:00 PM
sorrule's Avatar
Is your VSS working? I forgot my 2step was set at 4500 and test drove it while my VSS was busted and that's what it did because it's only supposed to stay on when you're not moving. Good luck
Old Jan 7, 2008 | 02:45 PM
Default Re: (sorrule)
cable....speed
Old Jan 8, 2008 | 12:44 PM
Default Re: (charlie_sohc)
never mind peeps .....found my owe problems..
Old May 19, 2008 | 04:04 PM
dseriesdrag's Avatar
so what was the problem with this car??? My car has the exact same problem!!!!
brad22486
13
Feb 6, 2021 08:08 AM
anakin550
Aug 10, 2010 02:17 PM
black0hatch
Jan 18, 2008 09:20 AM
slow_srt
Feb 6, 2007 08:08 PM
joker4096
May 24, 2006 01:57 PM
