2 questions (acl and eagle)
Old Nov 24, 2007 | 08:51 AM
anton_'s Avatar
Default 2 questions (acl and eagle)
i have brown main bearings and have to change 6 of them, can i run acl and have proper clearance?
whats the torque spec on the eagle rods (b16a)
Modified by anton_ at 1:09 PM 11/24/2007
Old Nov 24, 2007 | 03:53 PM
Turbo B18C EJ6's Avatar
Default Re: 2 questions (anton_)
ACL's are equilvent to green oem bearings. You should check your crank journals first with a micrometer and compare specs in a helms manaul, i also recommend that u use plasticgauge to verify clearances. dont chance it on your motor. GL.
Old Nov 24, 2007 | 03:56 PM
Tippyman's Avatar
Default Re: 2 questions (Turbo B18C EJ6)
Plastiguage the bearings after you swap them and make sure they're in spec. If not, then buy the needed OEM bearing.
Old Nov 24, 2007 | 05:30 PM
Maxcapacity's Avatar
What kind of bolts are you using?
Specs using Moly lube
ARP 2000 7/16" bolt with 7/16" bolt head 75ft lbs
ARP 2000 3/8" bolt with 7/16" bolt head 43ft lbs-* these came on my eagle rods*
ARP 2000 5/16" bolt with 3/8" bolt head 28ft lbs, and if using stock bolts ? In my manual for the b16 stock bolts/rods are 30ft lbs.
Old Nov 25, 2007 | 03:05 AM
anton_'s Avatar
Default Re: 2 questions (Tippyman)
ok, but can i mix acl and oem?
kidd_drastic
Jan 28, 2006 10:04 AM
Boostless97Lude
Dec 26, 2005 12:39 PM
B20bTurbo
Oct 3, 2005 11:56 AM
blufke
Feb 19, 2004 08:05 AM
