2 bar map
Old Apr 21, 2003 | 08:32 PM
rrei's Avatar
Default 2 bar map
can i use the gm 2 bar map as a direct replacement for the stock honda map. will the voltage be the same. i wanna run more than 11, like 12- 14psi. i an using afc hack also. this is possible right
Old Apr 21, 2003 | 09:57 PM
MiraiZ's Avatar
Default Re: 2 bar map (rrei)
Q:Can you use it for 15psi...
A: Actually good for only 1 BAR of positive atmospheric pressure or roughly 14.7psi
Q: Same voltage as stock?
A: I don't think it is...you"ll need somthing that can compensate the difference.
FWD_BEAST
Oct 9, 2012 04:24 PM
b18 hatch mike
Aug 29, 2008 09:33 PM
johnls
Sep 21, 2007 06:08 AM
turboeg77
Feb 26, 2006 04:18 PM
Javier
Mar 10, 2003 03:58 PM
