18psi safe on 93octane+9:1 compression
Old Apr 17, 2007 | 03:29 PM
wfocrx's Avatar
Default 18psi safe on 93octane+9:1 compression
I wanted to build a high compression lower boost motor; but, I think I would rather have a 9:1 motor. is 18psi about the limit for what you can safely run on pump gas (provided motor is built) turbo is a 50trim t3/t04e .63hot w/ d16z6
Old Apr 17, 2007 | 04:19 PM
tony413's Avatar
Default Re: 18psi safe on 93octane+9:1 compression (wfocrx)
depends on how cool you can keep the motor. also run the turbo at which it has the Greatest efficency for your powerband that will tel you how much boost you should run and if its safe
Old Apr 17, 2007 | 04:22 PM
A.E Motoring's Avatar
Default Re: 18psi safe on 93octane+9:1 compression (tony413)
u should be fine, i will be using 9:8
Old Apr 17, 2007 | 05:23 PM
slowteg90's Avatar
Default Re: 18psi safe on 93octane+9:1 compression (Dual Cam Racing)
^ 9:8 wow!!
Old Apr 17, 2007 | 05:24 PM
Default Re: 18psi safe on 93octane+9:1 compression (slowteg90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowteg90 &raquo;</TD></TR><TR><TD CLASS="quote">^ 9:8 wow!!</TD></TR></TABLE>
lol, yea im a lil scared about that **** too, leaves less room for error, =/
Old Apr 17, 2007 | 05:29 PM
slowteg90's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dual Cam Racing &raquo;</TD></TR><TR><TD CLASS="quote">
lol, yea im a lil scared about that **** too, leaves less room for error, =/</TD></TR></TABLE>
well actualyl i was being sarcastic.. you said 9:8 , when you really meant 9.8 ... i know what you meant, just a lil joke... lol.. 9.8:1 isnt too high, you just need a good tuner and good EMS
Old Apr 17, 2007 | 05:38 PM
well actualyl i was being sarcastic.. you said 9:8 , when you really meant 9.8 ... i know what you meant, just a lil joke... lol.. 9.8:1 isnt too high, you just need a good tuner and good EMS</TD></TR></TABLE>
hahah, =P
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wfocrx &raquo;</TD></TR><TR><TD CLASS="quote">I wanted to build a high compression lower boost motor; but, I think I would rather have a 9:1 motor. is 18psi about the limit for what you can safely run on pump gas (provided motor is built) turbo is a 50trim t3/t04e .63hot w/ d16z6</TD></TR></TABLE>
It's all about torque and heat. 18psi on that turbo is cake as far as heat goes. Just don't make more then around 280-300wtrq and you'll be fine on pump gas.
josh tavares
13
Jun 14, 2008 04:04 AM
boosted94teggy
Sep 19, 2005 12:34 AM
1.8
Jan 30, 2005 06:11 PM
Soon_2b_evil
Oct 9, 2003 06:25 AM
CiViC SiR
Oct 3, 2003 04:27 PM
