14b Question
Old May 7, 2005 | 07:22 AM
Novtecdohc's Avatar
Default 14b Question
Does anyone know if the o2 housing on the 14b clear the lower crossmember on a 90-93 Integra?
Old May 7, 2005 | 07:52 AM
93cicvicls's Avatar
Default Re: 14b Question (Novtecdohc)
dont think a stock o2 will fit .i had my welded, closed off 1 side and had the other welded into 1 downpipe.ill try to get a pic of my setup its no longer int he car (93eg with ls swap).i had a roblem with the oil return flange, and it wasnt a fit problem just getting the right1.car ran 15.5/88mph with bad clutch no boost.looking to get in the high 12s with the 14b back on
Old May 7, 2005 | 09:39 AM
drift2004's Avatar
Default Re: 14b Question (93cicvicls)
u can probably fit it if u cut part of it or something, why not get traction bars? although depending were the turbo sits u can fit a 3 inch downpipe with no modification because that is my situation in my car
Old May 7, 2005 | 09:53 AM
Novtecdohc's Avatar
Default Re: 14b Question (drift2004)
I cant get the stock o2 hosung for the turbo fo fit so i might have to do somthing custom
Old May 7, 2005 | 09:58 AM
used2baracer's Avatar
Will only fit if you have the compressor side towards the passanger side and the turbine side on the drivers side.... if not, buy a flange from roadraceengineering.com ... you can make your own downpipe and the flange is only like $25 + shipping. I also have one I'll sell a little cheaper (pm if interested).
Old May 12, 2005 | 05:20 PM
14bcoupe's Avatar
Default Re: 14b Question (used2baracer)
[QUOTE=used2baracer]Will only fit if you have the compressor side towards the passanger side and the turbine side on the drivers side.... if not, buy a flange from roadraceengineering.com ... you can make your own downpipe and the flange is only like $25 + shipping. I also have one I'll sell a little cheaper (pm if interested).
yes this is very true but also depends on the manifold 9 out of 10 times you ll have that use that flanged like i had to and make your own custom 3inch downpipe to fit the tight spaces.
Old May 12, 2005 | 05:26 PM
USDM 4G VTEC's Avatar
not sure
but it doesnt clear the 88-91 Civic /CRX
to big of a member
the integras are a lot alike
so i guess it wont
crashsvg
Aug 13, 2010 02:07 PM
vtec_lude
Welding / Fabrication
Apr 13, 2008 11:34 AM
TrunkRattlin
May 4, 2006 09:51 PM
ringgold
Feb 12, 2004 02:02 PM
