14B Fittings Question
Old Jul 11, 2005 | 05:11 AM
CivicMike's Avatar
Default 14B Fittings Question
Im almost done gathering parts for my turbo install just need to know what size thread are on the turbo oil feed inlet and both the coolant line threads.......Both are banjo bolts but not sure what thread size they are. Also if you know where I can find banjo to AN fittings post that up as well. And for my last question what size bolts should i use to bolt turbo to manifold and turbo to downpipe? (are there special bolts for high-temp usage?)
Old Jul 11, 2005 | 06:02 AM
USDM 4G VTEC's Avatar
Default Re: 14B Fittings Question (CivicMike)
i went to home depot and to the air tools section and i got the fittings that can let u clamp a hose to the coolant lines
as for the oil feed fitting, ask Flamenco-T here he sold me the oil feed kit
as far as the bolts, they are 1.25 (fine thread) and the 30mm long ones are sufficient
Old Jul 11, 2005 | 10:13 AM
Flamenco-T's Avatar
Default Re: 14B Fittings Question (USDM 4G VTEC)
The oil inlet is 7/16-24 I.F. Only and the coolant is 14x1.50mm.
Let me know if you need any of these parts, we keep too many in stock lol
stan
EGcivic_95
May 3, 2011 06:08 PM
civic-r11
Jul 26, 2010 03:24 PM
integra-modder
Nov 24, 2003 09:57 PM
cvcc
Apr 29, 2003 07:30 PM
acman1
Apr 23, 2003 06:05 PM
