OIL RETURN flange AND OIL FEED bolt size for Garrett?
I remember in a post stan wrote that the oil return flange bolt size was 8mm x 1.25 and long 20mm. I got the bolts and am doing the install and they dont appear to work....
Also, I got a brass 45 degree fitting for screwing into the turbo. I think its a 1/8 fitting, but cant remember, mcmaster site order look up feature is currently down... This fitting falls into the hole...
So if you happen to know the correct size for this, let me know.
Re: OIL RETURN flange AND OIL FEED bolt size for Garrett? (integra-modder)
Mcmaster site can go down, but mine here never sleeps
the fitting to the turbo is 1/8" NPT for 5 bolts turbo and 1/4" for 4 bolts turbo
the garrett uses either 8x1.25mm or 3/8-16
stan
stan
Re: OIL RETURN flange AND OIL FEED bolt size for Garrett? (Optiks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Optiks »</TD></TR><TR><TD CLASS="quote">im pretty sure flmaenco t is right check his title </TD></TR></TABLE>
the fittings i bought are what he said originally...and they didnt fit, so I want to get someone else to verify this..... (stan = flamenco t, look at my post again)
Some Garrett turbo's don't come with a threaded oil feed hole, so people thread them. Did you buy the turbo used?
Re: OIL RETURN flange AND OIL FEED bolt size for Garrett? (CRV Monster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRV Monster »</TD></TR><TR><TD CLASS="quote">Some Garrett turbo's don't come with a threaded oil feed hole, so people thread them. Did you buy the turbo used? </TD></TR></TABLE>
no, brand new turbo from kyle... ^^^
oil feed thread: 1/4 inch
oil return flange bolt size: 3/8 inch
Home Depot
Going there 7 times today:
Home Depot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder »</TD></TR><TR><TD CLASS="quote">
the fittings i bought are what he said originally...and they didnt fit, so I want to get someone else to verify this..... (stan = flamenco t, look at my post again)</TD></TR></TABLE>
I told you both info in the original reply...trust me you need to read my reply carefully again
stan
stan
Re: OIL RETURN flange AND OIL FEED bolt size for Garrett? (Flamenco-T)
The guy from cheapturbo told me (for the 4-bolt style) the oil drain was 10x1.25 and it was actually 3/8-16, it depends on if your garrett was made stateside or in japan.\
Oil feed, listed to flamenco.
Modified by mike1114 at 8:29 PM 11/24/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T »</TD></TR><TR><TD CLASS="quote">
stan
misunderstanding stan.....
I was referring to your post where you said what it was...
stan
RC000E
05-04-2007 08:47 PM
