14B on B16
Old Mar 12, 2004 | 03:41 PM
CarAudiophile's Avatar
Default 14B on B16
(14B = 1G DSM Turbo for those that didn't know)
Some tell me it will flow enough air.. Some tell me it wont..
I want 6psi.. Will it hold it all the way to Redline?. (8200)
Old Mar 12, 2004 | 04:57 PM
danl's Avatar
Banned
Default Re: 14B on B16 (CarAudiophile)
Oh, it'll hold 8 psi to redline allright. Might be a little hotter than you want. Depending on your setup its a good 250whp turbo. If your flowing more than 280 whp worth of air at 8 psi, step up to a 16b, big 16g, 20g, or do the right thing and go garret.
Old Mar 12, 2004 | 04:58 PM
RedStarGsr's Avatar
i HIGHLY doubt it...why not buy a t3 off ebay for $100-$200?
you are also going to have to worry about getting a manifold to fit...
Old Mar 12, 2004 | 05:54 PM
danl's Avatar
Banned
Default Re: (RedStarGsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedStarGsr &raquo;</TD></TR><TR><TD CLASS="quote">i HIGHLY doubt it...why not buy a t3 off ebay for $100-$200?
you are also going to have to worry about getting a manifold to fit...</TD></TR></TABLE>
Dude, it'll hold 8psi to redline, unless he is flowing more than 300whp worth of air at only 8psi. I mean, I only ran a 14b on a 2L motor for 2 years. I've had it hold 20 psi to 7500 rpm's for 101 mph traps.
Old Mar 12, 2004 | 06:23 PM
ApexiChild's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarAudiophile &raquo;</TD></TR><TR><TD CLASS="quote">(14B = 1G DSM Turbo for those that didn't know)
I want 6psi.. Will it hold it all the way to Redline?. (8200)</TD></TR></TABLE>
well I think i will not hold till redline cause I know for a FACT that on a b16a1 with GSR cams, TUNED via hondata at 10psi on a greddy 15G the power starts to FLATTEN out at 7500rpms but it does not drop off it just flattens out.
so if that happens on a 15G
a DSM 14b would be if not smaller ... certianly not larger flowing than the 15G.
I think it would be and OK streetable turbo.... meaning it would pull very smooth power band like and almost feel stock w/out the HUGE shock to the motor of reaching full boost at 4500rpm with a t3t4.
again I would still boost with a 14b cause boost is better than no boost.
HTH
Old Mar 12, 2004 | 09:07 PM
dunkd's Avatar
i was looking at one of those turbos in a dsm at my friends shop and boy is it a baby turbo... just get a t3 for a couple extra bucks..
Old Mar 12, 2004 | 09:34 PM
b16ahybrid's Avatar
Default Re: (danl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danl &raquo;</TD></TR><TR><TD CLASS="quote">I only ran a 14b on a 2L motor for 2 years. I've had it hold 20 psi to 7500 rpm's for 101 mph traps.</TD></TR></TABLE>
101mph traps w/20psi...something isn't rite there.
I sure hope your trapping a lot higher then 101mph w/20psi. i'm trapping @ 109mph with 9psi.
Anyways I don't know much about the dsm turbo's but I can tell you this If it's the same size or smaller then the saab t3 (.42 compressor .48 exhaust) then It's definatly NOT going to hold boost till redline. I ran that turbo on my b16 and boost would drop from 6psi down to about 2-3psi by redline. It would start to fall about 5k rpm.
Old Mar 12, 2004 | 11:02 PM
Charles B.'s Avatar
Default Re: (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">
i think that 20psi is on a 4g63
Old Mar 13, 2004 | 03:03 AM
danl's Avatar
Banned
Anyways I don't know much about the dsm turbo's but I can tell you this If it's the same size or smaller then the saab t3 (.42 compressor .48 exhaust) then It's definatly NOT going to hold boost till redline. I ran that turbo on my b16 and boost would drop from 6psi down to about 2-3psi by redline. It would start to fall about 5k rpm. </TD></TR></TABLE>
Its on a 7.8:1 compression 4g63. You have to understand how many restrictions their are on a stock DSM. But, it held the boost. Hell their is a guy in the northeast that ran some 11 second passes on the 14b. Like I said, its a good 250whp turbo.
http://www.dsmtimes.org/turbo.htm
Old Mar 13, 2004 | 06:29 AM
b16ahybrid's Avatar
Default Re: (danl)
http://www.dsmtimes.org/turbo.htm</TD></TR></TABLE>
Ok, Like I said prior, I cant speak for dsm's because I never owned one. I Was thinking honda and 20psi. makes sense now.
Old Mar 14, 2004 | 08:27 AM
Infinity_Racer's Avatar
anyone know how a td05-14b compares to a t3 (.42 comp, .48 turbine)?
Old Mar 14, 2004 | 09:01 AM
yimmy's Avatar
Default Re: (Infinity_Racer)
My friend has a 14b on his b16 running 8psi and he ran a 13.1@107. It seems to make power all the way to redline. I think he dynoed 230 whp.
Old Mar 14, 2004 | 10:58 AM
danl's Avatar
Banned
Default Re: (yimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yimmy &raquo;</TD></TR><TR><TD CLASS="quote">My friend has a 14b on his b16 running 8psi and he ran a 13.1@107. It seems to make power all the way to redline. I think he dynoed 230 whp.</TD></TR></TABLE>
Thats a really strong trap. I bet he makes a LOT of torque as well at lowish rpm's. The thing I loved about the 14b is how it could fry the tires from a 2000rpm tromp, probably a 2500rpm tromp on a b16. SO basically the peak hp might not be enough for people to jerk off to, but the acuall power under the curve is where it really shines. I think the 107mph trap speaks for itself.
Old Mar 14, 2004 | 01:25 PM
b16ahybrid's Avatar
Default Re: (danl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danl &raquo;</TD></TR><TR><TD CLASS="quote">Thats a really strong trap. I bet he makes a LOT of torque as well at lowish rpm's. The thing I loved about the 14b is how it could fry the tires from a 2000rpm tromp, probably a 2500rpm tromp on a b16. SO basically the peak hp might not be enough for people to jerk off to, but the acuall power under the curve is where it really shines. I think the 107mph trap speaks for itself.</TD></TR></TABLE>
The 14b must flow more then a t3 (saab .42/.48) because thats what I ran on my b16 for a while, I couldn't get my traps higher then 103mph (13.7)
I swapped out for a t3t4 and my traps went up to 109mph (13.5). Also I say that because I couldn't keep boost if my life depended on it (above 5krpm)
Old Mar 14, 2004 | 07:57 PM
so how does the 14b compare to a .42/.48 t3?
Old Mar 14, 2004 | 08:42 PM
blown_LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Infinity_Racer &raquo;</TD></TR><TR><TD CLASS="quote">so how does the 14b compare to a .42/.48 t3? </TD></TR></TABLE>
I ran t3 on b18 teg i ran like 7 psi on it and it pulled really good to red line. On the other hand i got 14b on my dsm (stock) and i'm boosting 17 psi, but i'll drop like **** after 6k. The boost will fall to like 13-14 psi at 7k. Once I reved it to 7.5k and it only had like 11 psi.
Old Mar 15, 2004 | 11:46 AM
Default Re: (blown_LS)
thanks...
does anyone else know how the small t3 is compared to the 14b? tryin to piece together a kit for 10 psi so i just want to see which of the two is bigger
supracharger
Oct 6, 2008 05:05 PM
mra4886
Aug 24, 2006 04:06 PM
motormike40
Aug 9, 2006 01:37 PM
huntarrr
Jan 16, 2005 11:15 AM
ZoNe_HKS
Aug 26, 2003 05:40 PM
