12an return line or 10an
Old Mar 13, 2003 | 09:29 AM
boostin b16's Avatar
Default 12an return line or 10an
anyone here running a 12an return line? is the bigger size really necessary? does anyone here have drainage problems with aeroquip 10 an fittings for there retun line? any opinions welcome ... advantages and disadvantages!
Old Mar 13, 2003 | 09:39 AM
SiRkid's Avatar
Default Re: 12an return line or 10an (boostin b16)
10
Old Mar 13, 2003 | 09:50 AM
jinxproof99's Avatar
New User
oil. alright.
[Modified by jinxproof99, 2:11 PM 3/13/2003]
Old Mar 13, 2003 | 10:03 AM
Sonny's Avatar
Default Re: 12an return line or 10an (jinxproof99)
I think he's talking about oil return, not fuel return.
My turbo's oil return is -10 AN.
Sonny
Old Mar 13, 2003 | 10:25 AM
darkracer's Avatar
Default Re: 12an return line or 10an (Sonny)
sorry to jack thread, but kinda related, where do you get oil lines and fittings cause i just bought a T25 from this guy and he didn't have the lines, fittings, nothing , just the turbo. clean though, good condition and only cost $160 thanks for the help, oh BTW going to put into a 91 CIvic hb
Old Mar 13, 2003 | 12:59 PM
Flamenco-T's Avatar
Default Re: 12an return line or 10an (darkracer)
use a -10, -12 is too big...
Darkracer, email me at ex_jesuit@yahoo.com and tell me the make of your turbo
I'll put a kit for you
stan
Old Mar 13, 2003 | 01:21 PM
SuperT's Avatar
Default Re: 12an return line or 10an (Flamenco-T)
I use a -12 in my drag truck but its a little overkill...but -10 is just fine too...
Dave
Old Mar 13, 2003 | 01:23 PM
ridnmyhonda's Avatar
Default Re: 12an return line or 10an (SuperT)
i got 1/2"
Old Mar 13, 2003 | 01:27 PM
i just called turbonetics for some info and they said to run a 10 at the minnimum!! they said they would rather run a 12 but a 10 will work. they said they feel safe with 12an fittings because different manufacturers of 10ans use differnt inside diameters. some are too small and my cause a dranage problem! they recomended using 10an fittings if you drill out the inside a bit.
Old Mar 13, 2003 | 01:28 PM
Flamenco-T's Avatar
Default Re: 12an return line or 10an (ridnmyhonda)
-10AN is equivalent to 5/8"
-12AN is equivalent to 3/8"
1/2" is good enough as well, it's about a -8AN size..
stan
Old Mar 13, 2003 | 02:23 PM
niedejb's Avatar
stan
-12 is 3/4"
Old Mar 13, 2003 | 03:45 PM
UberTeg's Avatar
3/8" is 6an
Old Mar 13, 2003 | 03:56 PM
tony1's Avatar
stan
C'mon stan, i expect more than this from you...
We run a -12 return and it is better than running a -10. Realistically, however, you probably won't see much of a difference either way. You want the return to be as free flowing as possible so bigger is better until the point where it doesn't make a difference anymore. I don't really see a need to go to -16 because the oil can't flow out any quicker. We actually run the scavenge of our dry sump pump on the oil return to pull the oil out.
Old Mar 13, 2003 | 05:24 PM
ninesecteg's Avatar
Default Re: 12an return line or 10an (tony1)
you need about a half inch inside diameter on your return line. -10 is perfect!
Old Mar 13, 2003 | 05:25 PM
BoostedSi's Avatar
Default Re: 12an return line or 10an (ninesecteg)
i'm using 10an
Old Mar 13, 2003 | 07:31 PM
Flamenco-T's Avatar
OMG you're still here heheheheh...
I know..oops
Old Mar 13, 2003 | 07:51 PM
turbo craig's Avatar
i run a 12an on my teg seems to work fine, no problems yet
Old Mar 13, 2003 | 08:23 PM
DR. ON POINT's Avatar
Banned
Default Re: 12an return line or 10an (turbo craig)
either one is sufficiet...... just dont use that garden hose u get with drag kits
Old Mar 13, 2003 | 08:54 PM
turbologist's Avatar
Default Re: 12an return line or 10an (niedejb)
stan
-12 is 3/4"
for anyone that doesnt know here...in order to convert from AN to std just put the number over 16 and reduce..there ya have it kiddies
Old Mar 13, 2003 | 09:36 PM
Flamenco-T's Avatar
Default Re: 12an return line or 10an (UberTeg)
3/8" is 6an
sorry bad math...
k20em2
Oct 19, 2006 07:24 PM
1boostedcivic
Dec 14, 2004 03:51 PM
94lsboost
Nov 28, 2004 03:33 PM
delux247
Dec 27, 2003 02:00 PM
Del_Slowest
Nov 27, 2003 09:07 AM
