11.1-12.1 compression on boost?
Psi dosnt generally dictate power levels, what is your power goal? What turbo? What engine setup?
What fuel will be used?
Higher comp will require a higher fuel grade, e85 or 93. Perhaps running water/meth w/pump gas to be on the safe side. AEM makes a nice water/meth kit.
It can definately be done, just have to be on a decent/good fuel grade & have a good tuner. The margin for error in tuning becomes quite thin on higher comp setups.
my current setup consist of a stock ls with b16 nippon racing pistons, compression 11.3.1 roughly. im running 6 psi currently making 240 on e85. Talk about a fun *** car, the response is beyond awesome
94TealGSR
Jun 5, 2003 08:54 AM
