10ga fuel pump hot wire question
Old Jun 15, 2016 | 03:56 PM
carlos8's Avatar
Default 10ga fuel pump hot wire question
Hi, I have the typical 10ga wire from the battery to a 40amp relay. Today i was at a muffler shop and the guy see the hotwire with a 20amp fuse.
He told me the fuse before the relay is against the purpose of the hotwire. Is that true? i need to run the 10ga from the battery to the relay straight?
Old Jun 15, 2016 | 11:59 PM
2kdrift's Avatar
Default Re: 10ga fuel pump hot wire question
you should be running a 40a fuse or higher, what ever the rating on the fuse it will support that amperage before it pops
Honestly I dont typically use fuses in this situation but I make sure theres no way for the hot wire to short out. It would be recomended to use a fuse just make sure its the proper size, I would go with either a 40A or 50A
Old Jun 16, 2016 | 04:57 AM
Mjalaly's Avatar
^^^^ What he said ^^^^
every relay should be protected by a fuse.
Old Jun 16, 2016 | 06:14 AM
carlos8's Avatar
Thanks guys, 40amp fuse already in place.
Old Jun 16, 2016 | 06:19 AM
LightningTeg's Avatar
Community Builder
The 20amp is for the original fuel pump wiring. That wire is no longer under the load from the pump once you put a relay in with direct battery power.
latino honda
May 24, 2019 11:32 AM
93eg1
14
Oct 26, 2010 03:36 PM
97civic07gsxr
Dec 30, 2008 05:07 PM
fastludeh22
Dec 21, 2003 08:50 PM
Sloth
Sep 17, 2002 02:29 PM
