1000cc-20 PSI out of fuel?
Here is my setup
84mm AEBS sleeves
T6766
Front facing Manifold
Dual 255 Walbros
Skunk2 Pro 1's cams
Hondata S300
With my 1000cc injectors @ 20 PSI with pump gas I'm 85% at 8000 and 90% injectors duty at 9000RPM? is it normal?
Do I need to upgrade?
I except to go 30PSI with C16
84mm AEBS sleeves
T6766
Dual 255 Walbros
Skunk2 Pro 1's cams
Hondata S300
Re: 1000cc-20 PSI out of fuel?
yah what is your base man i have personally made 650 on rc1000's at 85psi of base not ideal but it worked for 2 years.
and i would do the corn over c16 but thats just me
Moderator in Chief
If you are injector limited you can try running less rpm, more boost. You will find rpm eats up injector quicker and your peak HP isnt at 9000rpm anyways.
You can also extend your injectors slightly by increasing the fuel pressure - assuming you have enough pump left.
I can switch for ID2000 or slightly less that is not a problem, the question was how many HP can I hit max with my ID1000?
Now there's an ignorant entry to your educational postings. Come on now.
The car wont run worth a **** with 2000's on gasoline. I tried before i fully switched to E85. Im sure with a LOT of tweeking i could have got it to run better but wasnt ideal at all. 20 psi with a 67MM has got to be a pretty decent amount of power. What fuel pump are you running? what regulator are you running. Give a complete rundown of the fuel system right down to the lines and wiring for the pump.
thats what i was thinking also, but thought i would leave it alone lol
Fuel pumps are 2 brand new walbro 255 with AN 10 feed
Fuel pressure regulator is AEM
Wiring is a 4mm from box fuse
I don t like E85 because it is not the fuel in winter and summer, even between two differents fuel station.
are they high pressure 255's or standard 255's . Nice 98 octane should be able to make some really nice power with that. I would increase base pressure and see where that gets you.
Gs342 Walbro I think they are standard.
What is the part number of the high pressure?
98 is RON pump fuel I don t know you get same fuel? I think it is your 93 oct fuel
what fuel pressure regulator are you running? rising rate right?
if you set it at 50-60, in my experience a single walbro setup with id1000, the fuel pressure falls off at high rpm...supposedly you should be hitting 80ish psi @ that boost levels, but if you record your FP, it will not go there.
id1000 on pump, 500 should be a cakewalk.
I m running 50 Psi base fuel pressure with AEM FRP and running 20 PSI so I m around the limit of the dual 255 walbro?
I heard people hitting 800 HP with dual 255?
aem fpr is not a rising rate.
that is your problem.
get an electronic fpgauge and monitor your fp @ high rpms...
aem is a 1:1 regulator, i dont care for them but they are rising rate. Both pumps should ahve their own dedicated 10 gauge wiring and 30amp relay.
AEM FRP see the boost pressure and adjust it.
I have only 1 wire for 2pumps one 70A fuse and one 60 relay, do you think it can affect the voltage? I can check that that point?
