***The Official JRSC Thread***
![Default](https://honda-tech.com/forums/images/icons/icon1.gif)
Do I need an aftermarket FPR for tuning?
I'm putting together stock B18C1 with LHT JRSC,Walbro 255 pump, RC 440's & Hondata S300.
If its not broke don't try to fix it.
might seem dumb but with my old setup I had the car dyno'd and tuned with a wideband 02 sensor. Once tuning was completed my stock sensor was put back in place.
Will running a wideband 02 sensor full time work properly? Does it need to be a PLX with resistors?
B18C
LHT JRSC
CRV Crank
Endyn Stepper
Hondata S200
B18C
LHT JRSC
CRV Crank
Endyn Stepper
Hondata S200
Judging by the color, I would say it is an Endyn. The MVM are purple colored and are laser etched with the MVM name. Both should have the same overdrive though.
B18C
LHT JRSC
CRV Crank
Endyn Stepper
Hondata S200
B18C
LHT JRSC
CRV Crank
Endyn Stepper
Hondata S200
I have the s300 and use closed loop with my PLX M300. I did use the resistor that are recommended.
You can use the wideband all the time. However, you won't be running in closed loop because only the s300 allows you to use a wideband in place of the narrowed for closed loop operation. the s200 does not support this.
HT White Ops
Anyone want to buy my setup? Just testing waters, wanting to go another way.
TW: Jackson Racing Supercharger for B16A/B16B/B17A/B18C5 -- $1200
![](https://farm5.static.flickr.com/4064/4666796689_eaf296dc6a_o.jpg)
Not sure if I want to get rid of this, but I'm entertaining serious offers. A deposit will have me remove it from my car.
* B16/B17/B18C5 Manifold
* Eaton Roots Charger (Magnusen Performance)
* 4.0" Nose Pulley (6lbs)
* Jackson Racing Crank Pulley (allows for true 6lb boost)
* Jackson Racing Double Alt-Pulley (Non-Stepped)
* All Belts, Hoses, Fittings, Brackets etc.
* Charger has recent oil change
* Golden Eagle 90-Degree FPR Adapter
* New Bypass Valve Actuator
Add-Ons:
* Hondata s200 w/ Boost Option, BURN1, and USB-DB9 Cable - $250
* RC SL9-550cc 13ohm with Press-Fit O-Rings - $250
* Walbro 255lph Fuel Pump (less than 100 miles) - $60
* GSR Comptech Intake -- $120
Total Package: $1700
Add-Ons:
HT White Ops
I never used the Hondata, it's brand new. I use Neptune RTP. And it's plugged in to the stock location because that's when I was using a 3-BAR GM map. It's currently there because I have nothing to plug the throttle body, but if you look at my previous posts, I have a stock map mounted to the manifold that runs my setup now.
![](https://farm5.static.flickr.com/4141/4850451360_598ffe357f_o.jpg)
But thanks for your concern.
^^ Can you tell me where the MAP hose is connected to in that pic? Thanks.
Also, anyone knows if I need to buy the Electrical kit from JRSC and their pressure switch if I'm not using their FMU? Trying to piece together my used JRSC kit.
HT White Ops
I took out the pressure switch (because I'm actually running REAL engine management) and put in a hose nipple with a standard 1/4" NPT. The hose it just slipped onto the nipple on the bottom of the MAP sensor.
And no, you don't need their electrical kit.
Thanks for the help man. Also, where did you get or how you made that hose nipple with the 1/4" NPT? The nipple under the MAP sensor is freaking tiny.
HT White Ops
I just found a silicone hose (it's actually a bit of OEM Honda vacuum hose) that fit over the MAP nipple, and then STRETCHED it over the brass nipple. I don't think the nipple itself is 1/4", it's more like 1/8". It's just the thread is 1/4" NPT.
I got it at a CarQuest auto parts, but just about any parts store that has loose brass will have this. Just bring in your manifold and find one that threads into the pressure switch hole.
so i got a couple questions before i go ahead with installing a JRSC on my civic
set up
2000 EM1
63,000 original miles
motor runs strong no issues what so ever
original clutch and doesn't seem to slip
1. will my clutch slip or hold up?
do i need to upgrade to stage 1
2. do i need new timing belt and tensioner
3. do i need a new water pump
build will consist of the following
JRSC kit with 8psi pulley
rc440
hondata s200
set up
2000 EM1
rc440
hondata s200
set up
2000 EM1
rc440
hondata s200
set up
2000 EM1
rc440
hondata s200
Has anyone in here used the spec + clutches? The stage 2+ or the stage 3+? Im looking for a new clutch and thinking about trying one of these out the stage 2+ says it will hold 280 ftlbs and the stage 3+ holds 400 ftlbs. I think the stage 2+ will be enough for my JRSC b20vtec setup but wanted to ask around. Any info on how these feel and the life and how well the hold up would be great thanks
group buys are not allowed on h-t, and you have to be a forum sponsor to resell items.
thanks.
thanks.
