<~~How about a b18b1~~>?
Old Apr 6, 2011 | 12:07 AM
blue91EF's Avatar
Icon3 <~~How about a b18b1~~>?
purchased a 92 JDM integra with b18b1 inside? must be a swap..
so anyway im thinking turbo but ide have to build the motor to do that so i was thinking just build the motor for a non turbo setup & just swap pistons later.
you think 60 over is outrageous? is 40 even practicable for a daily driver?
whats the best way to start? maybe cam gears lighweight pullys headers cai OR ram air first... then maybe valve springs & camshaft & new seals.
i dunno, any advice.///?
Old Apr 6, 2011 | 12:14 AM
UncleD's Avatar
Default Re: <~~How about a b18b1~~>?
I would ask these guys: https://honda-tech.com/forums/forumdisplay.php?f=16
Old Apr 6, 2011 | 05:59 PM
blue91EF's Avatar
i did such but post got deleted & i searched quite a bit for the exact info im looking for.
no disrespect but im wonding if anyone knows the biggest pistons honda makes for a b18b1
cuz if 20 over is the biggest honda will go i doubt 60 over is a good idea.
whats the biggest bore youve seen out of this motor? & work properly & also not blow up after a week.
i want to build it once properly
the turbo is down the line so for now im going all motor but i want to buy parts that will work for allmotor & turbo setup
pistons obviously will be either all motor or turbo build.
but what else might i do to help longevity & performance without deticating my morot to one setup or the other..
thank you.
Old Apr 6, 2011 | 06:05 PM
UncleD's Avatar
Some people push the stock sleeves to 82mm. I went 81.50 on mine. Nippon racing and Inline Four sells good OE cast pistons. There isn't really any secrets to building that bottom end...same as the others. Been done millions of times.
Old Apr 6, 2011 | 09:50 PM
blue91EF's Avatar
cast piston? most anything is forged nowadays not saying cast isnt better it its own way... stock i suppose./ so 84 0r 85 low compression with 28 lbs of boost ISNT gonna happen?
Old Apr 6, 2011 | 10:23 PM
UncleD's Avatar
Wow you've got allot of reading to do.
Again - you're asking FI questions in an NA sub forum. Go over there and ask them. 28 psi on what size turbo? A 16g? A 42R? What??
Don't answer, just go post in the correct forum. Please.
blue91EF
Apr 8, 2011 12:21 PM
ballinboosi
Apr 7, 2011 10:15 AM
jdmgeezer
Jun 2, 2008 10:41 AM
h22xcivic
21
Mar 16, 2007 10:28 AM
cshady911
Feb 7, 2005 08:24 AM
