*CC Fab update thread*
It is not really going to matter if he clocks it or not the compressor inlet will have to face down most likely and the area where it is in the pic offers the most clearance as that is the flattest area. I suggest getting another flange and either having it welded on to the turbo flange and using it basically as a spacer, that should give him enough space, the only concern is where that will position the turbo relative to the chasis. Other then that I don't see anything else that will fix the issue, the compressor housing is bigger then the turbine housing and the manifold flange.
I see what you are saying Josh, but If it does not fit the extra flange Idea should definately clear and if he gets the flange perfectly flat add some copper sealent and uses it as a sanwich he should be good right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccfab »</TD></TR><TR><TD CLASS="quote">i mocked it with a t3 60/63 with a .60 compressor housing and it fit fine. </TD></TR></TABLE>
whos this directed to
well boys I owe Josh an appology clocked that **** and i have like a quarter inch of clearance between the 2 so it now works and will also be pointing the correct way for my charge pipes. Just didnt look like it would work before i did it but it does give it a we bit of clearance to work.
anyone wants pics ?
edit: corey the mani clears both ways now before it was worse with the compressor on the driver side
anyone wants pics ?
yes you did sir my mistake
btw i mounted the turbo with the compressor on the passenger side because if the wastegate so that i can have the dumptube go back into the downpipe for a nice quiet setup
o and you forgot to add you sell manifolds!! notice all reall companies stay out of this thread and sell there own manifolds threw there own adds and posts.
more shipments tommorow guys
