** -- Can I run 11PSI on my b18b stock internals without troubles -- **
Hi, I know this question had been asked but it seems like the answer is not clear. How safe is it running 11-12psi on a stock internals b18b 1999 engine. I am currently running 8-9psi and abuse of it frequently for a month now, but it is still running so so strong... I have 450cc injectors with SMC+ as fuel management. I can add FPR and fuel pump if necessary.
Thanks
Thanks
Re: ** -- Can I run 11PSI on my b18b stock internals without troubles -- ** (Nine)
How safe would it be, as safe as what I am running now with my 8 psi?
Thanks
Thanks
Re: ** -- Can I run 11PSI on my b18b stock internals without troubles -- ** (mz3bo)
...of course running more boost is gonna wear your motor out faster, but i run 12 lbs. on my stock LS and drive it everday... alot and hard. planning to run 13 lbs. w/ t3/60-1 until i get a shortblock built. i would say go for it, you shouldnt have any problems if you run an FMU...
