** Calling All Stock Block B16 Turbos **
Re: ** Calling All Stock Block B16 Turbos ** (trboCIVICWRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trboCIVICWRX »</TD></TR><TR><TD CLASS="quote">I had a stock b16 last year in a full drag car... I was making 325+ & 212tq... and I ran 10.98...</TD></TR></TABLE>
nice numbers, but my car is gonna be a street car, which will have AC and power steering.
Re: (Pfieffdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pfieffdog »</TD></TR><TR><TD CLASS="quote">My neighbor will probably chime in here, but he made 307whp/211wtq on his b16 last year. t3/t4 60 trim .63 a/r I believe.</TD></TR></TABLE>
Wow, how much boost?
Guest
Posts: n/a
Re: (Pfieffdog)
it was 307whp/212 wtq beotchh..I was planning on using 550cc injectors and making ~350whp but had a prob. with the injectors and had to use some 450's in the end so they were about maxed out @ 307whp. Boost was ~14psi.
Re: ** Calling All Stock Block B16 Turbos ** (integlspwr2k)
The reason for this thread was too see if its possible to make 300whp on a stock b16 with AC and power steering.
I know its possible, but i want to see what setups you guys have to achieve those numbers.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k »</TD></TR><TR><TD CLASS="quote">The reason for this thread was too see if its possible to make 300whp on a stock b16 with AC and power steering.
I know its possible, but i want to see what setups you guys have to achieve those numbers.</TD></TR></TABLE>
My setup was:
b16a
Inline pro 2mm gasket (~9:1 compression)
ARP headstuds
SSAutochrome manifold
3" dp
T3/to4e 60 trim .63ar
Tial 35mm
Maxrev IC
Sheepdog BOV
hondata s100b
DSM 450's
Walbro 255hp
hope that helps
My setup was:
b16a
ARP headstuds
3" dp
Tial 35mm
Maxrev IC
Sheepdog BOV
hondata s100b
DSM 450's
Walbro 255hp
hope that helps
Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 »</TD></TR><TR><TD CLASS="quote">
it was 307whp/212 wtq beotchh..I was planning on using 550cc injectors and making ~350whp but had a prob. with the injectors and had to use some 450's in the end so they were about maxed out @ 307whp. Boost was ~14psi.</TD></TR></TABLE>
awesome numbers!! how long have you been running this stock setup and have you encountered any specific problems??
Guest
Posts: n/a
Re: (Chillinit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit »</TD></TR><TR><TD CLASS="quote">
awesome numbers!! how long have you been running this stock setup and have you encountered any specific problems??</TD></TR></TABLE>
I ran it from october to mid dec....then put it away for the winter. I changed a few things (bigger injectors, cams, etc) but still stock bottom end. I plan on making more power once i get it done.
Guest
Posts: n/a
Re: (JonnyCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonnyCoupe »</TD></TR><TR><TD CLASS="quote">Hows the SS autochrome manifold holding up Mpir?
And when do you reach your boost threshold?
CHeers
Jonny</TD></TR></TABLE>
the manifold is fine. I have the turbo braced off the block (no weight pulling down on the manifold) With my t3/t4 60trim .63ar i saw 14-15psi @ 4700rpms.
CHeers
Re: (hoggy)
i can add my 2 cents in on my last car.
It made 250HP & 174 TQ. this was on a Peice of **** Apexi b series turbo kit
boosting around 11-12 lbs.
Im not worried about the tuning part. I have one of the best tuners in hawaii with uberdata that is going to tune my stuff.
Re: (integlspwr2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k »</TD></TR><TR><TD CLASS="quote">i can add my 2 cents in on my last car.
Is that the same kit im buying from you
Re: (JonnyCoupe)
Is that the same kit im buying from you </TD></TR></TABLE>
nope completely different kit. The apexi one is a log style manifold vs the equal length one.
Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 »</TD></TR><TR><TD CLASS="quote">the manifold is fine. I have the turbo braced off the block (no weight pulling down on the manifold) With my t3/t4 60trim .63ar i saw 14-15psi @ 4700rpms. </TD></TR></TABLE>
do you have pics of your turbo bracing???
if not can you take some?
Re: ** Calling All Stock Block B16 Turbos ** (Bulldogg83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulldogg83 »</TD></TR><TR><TD CLASS="quote">Round 1-->00 Si w/ Stock JDM b16 + GT35E + 12lbs=306whp/215 wtrq on 93 Octane...Best Time-->13.0 @ 111mph on radials........
thats what im technically looking at..
300whp on a stock b16 motor.
what exact parts did you have on your setup?
Sometimes i have would be SX FPR, oneFab Manifold, Garret GT32 Turbo, Full 3" Down pipe, straight 3" exhuast NO BENDS all the way to the back, AEBS intake manifold fold, hondata IM gasket, Type R TB, AEBS FUel Rail, Greddy type 24 FMIC with Original Blitz HORN Style BOV, Cam Gears, but basically everything is else is stock, like the block and the head. Might swap em skunk 2 stage 1 cams, but thats still in the air. All this going into a first Gen B16.
