2 Stanton STR8-80's w/new needles!! Only $200!
That's right, I have run out of time to spin at home, and need to fund new projects. I am letting these babies go for a song, only $200 for the pair! I recently installed new styli on the stock headshells, Stanton 510SK's. They are in great condition, some minor scratches and the like, and even includes covers and slipmats! Here are some specs and pics below:
Features
Reverse and motor off functions
3.5mm line input built-in (for portable CDs, MDs, or any other line source) cable incluced
Key adjustment (A.K.A. master tempo)
Quartz lock (A.K.A. Pitch On/Off)
3 speeds: 33, 45, 78 rpm
Selectable pitch adjustment (+/-8%, 12%)
Skip-proof straight tone arm!
Blue LEDs
Remote Start
Adjustable feet
Includes dust cover and slipmat
SP/DIF digital output
Direct drive motor
Aluminum platter
Target light
Blue strobe indicator
Technical Info
Motor: 8 Pole, 3 Phase, Brushless DC motor
Turntable Platter: 330mm dia. Aluminum diecast
Wow and Flutter: Less than 0.20% WRMS (JIS WTD) with 33 1/3 RPM
S/N Ratio: More than 50dB (DIN-B)
Pitch Controls: +/-12%, +/-8%
Starting Torque: More than 1.6 kgf.cm
Braking System: Electronic Brake
Channel Separation: 16dB
Dimensions (W x H x D): 17-3/4 x 5 x 13-3/4 in.
Weight: 19 lbs
Features
Blue LEDs
Remote Start
Adjustable feet
Direct drive motor
Aluminum platter
Target light
Technical Info
Weight: 19 lbs
