Would a P2P ECU work with a D16Y7?
Old Aug 17, 2011 | 12:50 PM
Arseezy's Avatar
Default Would a P2P ECU work with a D16Y7?
I have a choice of running with a P2P ECU on my D16Y7,
Or I have a chipped P28 that I could use with it.
How would I go about doing this?
Should I get the P2P or use the P28?
And I also understand that the P28 is for Vtec, but I have a d16y7, so that's why I'm a bit confused lol.
I'm a noob so help me out.
Old Aug 17, 2011 | 02:27 PM
Arseezy's Avatar
Default Re: Would a P2P ECU work with a D16Y7?
Bump. Nobody knows?
Old Aug 17, 2011 | 06:13 PM
mtber's Avatar
A p2p ecu is for a d16y8 vtec engine with a 2 wire iacv (5 speed model).
A y7 motor is a non-vtec engine which uses a 3 wire idle air control valve.
You will need a y7 ecu or a chipped obd1 p28/p06/p75/pr4/p05 ecu with the iacv disabled for your y7 engine. If you choose this route I would recommend going to an intake manifold that uses a 2 wire iacv & re-wiring the iacv plug to 2 wire etc.
Old Aug 18, 2011 | 12:08 PM
Arseezy's Avatar
Thanks for the response.
I have a Z6 intake mani on the d16Y7 right now if that helps. How much do shops normally charge for disabling the iacv? My P28 is already chipped but I'm not sure if the iacv has been disabled.
Old Aug 18, 2011 | 05:16 PM
mtber's Avatar
If you have a z6 intake manifold chances are you have a 2 wire iacv wired up so you don't need to disable the iacv.
You may order a 28 pin eprom chip basemap from our website
http://www.phearable.net/shoppingcar...emap-p-60.html
& drop it into the ecu your self.
There is an instructional video on our website on how to change your eprom chip in an already socketed ecu.
http://www.phearable.net/tech
Daz-E
Southern California
12
Apr 22, 2013 07:07 PM
blackbmagic
Oct 6, 2009 05:29 PM
drift2004
Feb 27, 2008 01:53 PM
dumpeDc2
Jan 11, 2005 06:58 PM
dingusjt
Feb 11, 2003 07:16 AM
