VTEC pressure switch
Old Sep 4, 2011 | 06:31 AM
UDUBdriver's Avatar
Default VTEC pressure switch
Just recently my CEL came on and immediately following I noticed a lack of power in my car. I checked the code and it came out as code 22 or the VTEC pressure switch, should i just replace the switch or are there other steps I should take before replacing? any advice appreciated. thanks.
Old Sep 4, 2011 | 07:04 AM
HAMOTORSPORTS's Avatar
Default Re: VTEC pressure switch
I'd suggest unbolting the solenoid body from the head and checking the filter/screen to make sure it isn't blocked. Also, check your oil level and OIL PRESSURE. Lastly, check the wiring from the switch to ground on the thermostat housing, and from the switch to the ECU (Pin D6 for OBD1)
fw190bvi
Jul 23, 2009 03:17 PM
1SikEagle
Apr 11, 2009 01:02 PM
-Bionic-
Sep 2, 2006 04:50 PM
tinkerbell
Jan 1, 2005 08:00 PM
Tad
28
Sep 2, 2004 10:04 AM
