Unable to build boost
Old Sep 29, 2021 | 10:46 AM
  #26
alhara23's Avatar
Default Re: Unable to build boost
Max I’ve seen at wide open is 7 psi 3rd/4th I can take a video of what it does when I do that if that’s helpful
Old Sep 29, 2021 | 12:14 PM
  #27
Ryanthegreat1's Avatar
Build some pressure testing caps and pressure test from turbo intake to manifold. Really seems like a boost leak. Put 20psi in the system and see if it holds or find where it leaks. Could be a torn boot or loose clamp that opens up with pressure.
Old Sep 29, 2021 | 04:38 PM
  #28
alhara23's Avatar
I’ll try that when I get home.
do you think my blow off valve could be popping open? just trying to brainstorm
Old Sep 29, 2021 | 05:25 PM
  #29
I had thought about that but the manifold pressure on top of the piston should hold it shut. Unless it has a problem?
Old Sep 29, 2021 | 05:42 PM
  #30
alhara23's Avatar
I pulled it off and check and it seemed fine. The seal looks good still too. Do you think I can put a spring in there from the wastegate to make it heavier?
Old Sep 29, 2021 | 05:53 PM
  #31
But then it won't open when the manifold goes to vacuum.
You do have the blow off valve connected to the manifold right?
Old Oct 10, 2021 | 06:37 AM
  #32
Was it the blow off valve line?
owneyboy
Engine Management and Tuning
37
Sep 8, 2017 02:58 AM
BIG LUIS
Jul 31, 2014 08:00 PM
o 16K o
Apr 6, 2014 03:49 PM
stunnerone23
Sep 1, 2008 03:34 PM
