Type R Vavles in a b16 head?
Old Feb 8, 2009 | 06:46 PM
Mindgamez's Avatar
Default Type R Vavles in a b16 head?
So i have a Type R head that is Fuxed. I am taking the valve terrain and rocker arms and putting them into a b16 head. Will the Valves from the type R head fit into a b16 Head or does the .2 leter displacment make a diff so that there too big?? And can a machiene shop fix this?
Old Feb 8, 2009 | 08:04 PM
sander's Avatar
2.7(p/t)
Default Re: Type R Vavles in a b16 head?
If you are asking if you can put Type-R valves in a b16 head, yes you may. FYI, a Type-R head casting is a B16 head.
Old Feb 9, 2009 | 05:31 AM
zman's Avatar
with a head that fubar'd the valves are OK?
Yes, you can use the ITR valves in your head, like sander said both the ITR and b16 use the PR3 casting.
Old Feb 10, 2009 | 11:53 AM
Mindgamez's Avatar
Only the ones in that cylinder are fubar'd. The rest are fine. I have a bunch of other type R valves laying around from other projects that im goin to use to replace them.
Any one know if a machiene shop can fix this??
Old Feb 10, 2009 | 01:01 PM
zman's Avatar
yes, but you'll pay out the *** for them to fix it by welding/reshaping the combustion chamber. My buddy had a head fixed that dropped a valve. It was like $500 CDN to fix the 1 combustion chamber IIRC
Old Feb 12, 2009 | 04:10 PM
sauceja's Avatar
If you are using valves from 1 motor into a 2nd motor a valve job would almost be neccessary to make sure they seat correctly. Of course you prolly already know this though.
SmoKez
May 10, 2012 08:56 AM
Sr420Det
Mar 20, 2009 01:25 AM
Sr420Det
Mar 19, 2009 05:57 PM
2 0 3
Mar 30, 2003 06:50 AM
