lsvtec gsr head s300
Old 01-23-2010, 07:24 PM
B-outAteam's Avatar
Icon2 lsvtec gsr head s300
bear with me don't know much about tunning...I have 99 civic coupe lsv turbo coming soon...getting honadata s300.. ?Do i need to get y band to tune..or its all thru the ecu...
Old 01-24-2010, 07:14 AM
K20EF8Dx's Avatar
Default Re: lsvtec gsr head s300
if you are doing the tuning yes you will need to buy a wideband. if your are not then no you wouldnt. the wideband would be hooked up to an input on the ecu.
Old 01-24-2010, 10:01 AM
93turbo16's Avatar
A wideband is always a good thing to have in the car, I would suggest getting one even if you won't be tuning the car yourself.
If you are taking your car to a tuner, which I would suggest since you are asking a question like this, then the tuner will supply the wideband for the tuning session so you wouldn't absolutely need to have one.
jdm_h22
Engine Management and Tuning
26
05-30-2011 06:25 PM
97_gsr
07-14-2007 08:45 AM
Schister66
12-01-2005 03:21 PM
Group 03
10-15-2001 06:18 AM
Quick Reply: lsvtec gsr head s300
