Try my tool for FreeLog and Crome! EasyMap!
New! Version 2.1 released!
I have designed this tool (EasyMap) using Excel. To use this tool, you will need your Crome fuel and ignition tables, Freelog data (CSV files), and Excel.
What the tool does is allow the user (you) to input the datalogged session into the tool to display the AFRs logged during the session in the same table format that your tuning tables are based on.
With the 2.0 version of EasyMap, you don't need a version for Freelog and Crome Pro - you just need one. You can import either a FL CSV file or a CromePro CSV file and they'll both work.
You can also easily change the data 'filters' to only show data you want to look at.
- Say you only want to look at data when your ECT is 170F to 182F, you can do that.
- Or, you only want to look at data when your RPM is 1252 to 1500, you can do that.
You can also change the plotting variable now, so that on the table that's normally used for AFR, you can also plot TPS, IAT, ECT, and all the other variables. This will be VERY helpful for tuners with VERY modified cars that they wish to change the MAP-TPS tables for closed-loop operation.
This will also be very useful for tuners looking to do trending on AFR response to ECT and IAT to accurately tune the ECT/IAT compensation tables.
I'VE ALSO just added the graphing sheet so that tuners that prefer to view things in graphical format can do this easily as well.
You can easily change ANY and ALL of these filters to your liking.
- minimum Hits to display AFR
- max and min Speed
- max and min Gear
- max and min RPM
- max and min ECT
- max and min IAT
- max and min O2 AFR
- max and min MAP
- max and min TPS
- High Cam and Low Cam data
- and rule out data that may be altered by Tip-In
Happy tuning.
EasyMap (Download Link)
- Latest version is 2.1. Please delete older versions.
EasyMap How-To (Download Link)
- max and min Speed
- max and min Gear
- max and min RPM
- max and min ECT
- max and min IAT
- max and min MAP
- max and min TPS
Happy tuning.
1.8T_EG
Jan 19, 2004 04:08 PM
